Last updated Nov 6, 2025
Root privileges requirements
You need root privileges (sudo su) to deploy Automation Suite. The following sections describe the specific components that require root access and why they require it.
Node configuration
The following components require root access to configure the machines to install Automation Suite. This is required because the default partitioning structure on RHEL machines is not suitable for installing Kubernetes. All of these components are required on all nodes.
Component
Why is root required to execute?
parted
Required to update the partition structure.
pvresize
Required to resize physical volume.
lvextend
Required to extend logical volume.
xfs_growfs
Required to expand an XFS filesystem.
mkfs.ext4
Required to build a Linux filesystem.
mount
Required to mount a filesystem.
Deployment
The following components are required to execute the Automation Suite installer at the time of installation. All Linux components require root to be installed.
Component
Node(s) the component is required for
helm
Server and Agent
argocd
Server
jq
Server and Agent
curl
Server and Agent
openssl
Server and Agent
uuidd
Server and Agent
nc
Server and Agent
httpd-tools
Server and Agent
iscsi-initiator-utils
Server and Agent
iscsid
Server and Agent
rke2 services with Kubernetes
Server and Agent
longhorn
Server and Agent
podman1
Server
1 Only required for offline installation
Runtime
Of the components that were installed, the following run as root during normal Automation Suite cluster operations.
Component
Node(s) the compenent is required
Server and Agent
Required to provide the server daemon for the Internet Small Computer System Interface (iSCSI) protocol, as well as the utility programs used to manage it.
iscsid
Server and Agent
Required to implement the control path for iSCSI protocol for distributing disk access using SCSI commands sent over Internet Protocol networks, plus some management facilities.
Server and Agent
Required to configure containers and networking rules in the Kubernetes distribution.
longhorn
Server and Agent
Required to manage block storage between containers and the disks on the machines.
  • Node configuration
  • Deployment
  • Runtime
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
