- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Pre-installation, you cannot update the expiration time for the token used to authenticate to the host- and organization-level Management portals. Therefore user sessions do not time out.
To set a time interval for timeout for these portals, you can update the accessTokenLifetime property.
The following example sets the timeout interval to 86,400 seconds (24 hours):
UPDATE [identity].[Clients] SET AccessTokenLifetime = 86400 WHERE ClientName = 'Portal.OpenId'
