- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
The following issues can happen if you install RHEL 8.4 and are performing the offline installation, which requires podman. These issues are specific to podman and the OS being installed together.
Potential issue
- you cannot install both of the following on the cluster:
podman-1.0.0-8.git921f98f.module+el8.3.0+10171+12421f43.x86_64podman-3.0.1-6.module+el8.4.0+10607+f4da7515.x86_64
- package
cockpit-podman-29-2.module+el8.4.0+10607+f4da7515.noarchrequirespodman>=1.3.0, but none of the providers can be installed - cannot install the best candidate for the job
- problem with installed package
Potential issue
package
podman-3.0.1-6.module+el8.4.0+10607+f4da7515.x86_64requirescontainernetworking-plugins>=0.8.1-1, but none of the providers can be installed -
you cannot install both of the following:
containernetworking-plugins-0.7.4-4.git9ebe139.module+el8.3.0+10171+12421f43.x86_64containernetworking-plugins-0.9.1-1.module+el8.4.0+10607+f4da7515.x86_64
package
podman-catatonit-3.0.1-6.module+el8.4.0+10607+f4da7515.x86_64requirespodman=3.0.1-6.module+el8.4.0+10607+f4da7515, but none of the providers can be installed -
podman-catatonit-3.0.1-6.module+el8.4.0+10607+f4da7515.x86_64(try to add
--allowerasingto command line to replace conflicting packages or--skip-brokento skip uninstallable packages or--nobestto use not only best candidate packages)
Solution
You need to remove the current version of podman and allow Automation Suite to install the required version.
- Remove the current version of podman using the
yum remove podmancommand. - Re-run the installer after having removed the current version, which should install the correct version.
