Last updated May 8, 2026
Patch artifact download links
This page provides the download links for the artifacts required to apply a patch.
2023.10.12 patches
This section provides the download links for the artifacts required for Automation Suite 2023.10.12 patches.
2023.10.12+patch1
as-images.txt
To download as-images.txt for Automation Suite 2023.10.12+patch1, run the following command:
wget -O as-images.txt https://download.uipath.com/automation-suite/2023.10.12+patch1/embedded-images.txt
as-helm-charts.txt
To download as-helm-charts.txt for Automation Suite 2023.10.12+patch1, run the following command:
wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.12+patch1/embedded-helm-charts.txt
mirror-registry.sh
To download mirror-registry.sh for Automation Suite 2023.10.12+patch1, run the following command:
wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.12+patch1/mirror-registry.sh
hydrate-registry.sh
To download hydrate-registry.sh for Automation Suite 2023.10.12+patch1, run the following command:
wget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.12+patch1/hydrate-registry.sh
as.tar.gz
To download as.tar.gz for Automation Suite 2023.10.12+patch1, take one of the following steps:
  • To download the full as.tar.gz, run the following command:
    wget -O as.tar.gz https://download.uipath.com/automation-suite/2023.10.12+patch1/as-2023.10.12+patch1.tar.gz
  • To download the split as.tar.gz, run the following command:
    https://download.uipath.com/automation-suite/2023.10.12+patch1/as-2023.10.12+patch1-part-001
    https://download.uipath.com/automation-suite/2023.10.12+patch1/as-2023.10.12+patch1-part-002
as-fs.tar.gz
To download as-fs.tar.gz for Automation Suite 2023.10.12+patch1, run the following command:
wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2023.10.12+patch1/as-fs-2023.10.12+patch1.tar.gz
docker-images.json
To download docker-images.json for Automation Suite 2023.10.12+patch1, run the following command:
wget -O docker-images.json https://download.uipath.com/automation-suite/2023.10.12+patch1/docker-images.json
versions.json
To download versions.json for Automation Suite 2023.10.12+patch1 run the following command:
wget -O versions.json https://download.uipath.com/automation-suite/2023.10.12+patch1/versions.json
2023.10.7 patches
This section provides the download links for the artifacts required for Automation Suite 2023.10.7 patches.
2023.10.7+patch1
as-images.txt
To download as-images.txt for Automation Suite 2023.10.7+patch1, run the following command:
wget -O as-images.txt https://download.uipath.com/automation-suite/2023.10.7+patch1/embedded-images.txt
as-helm-charts.txt
To download as-helm-charts.txt for Automation Suite 2023.10.7+patch1, run the following command:
wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.7+patch1/embedded-helm-charts.txt
as.tar.gz
To download as.tar.gz for Automation Suite 2023.10.7+patch1, take one of the following steps:
    wget -O as.tar.gz https://download.uipath.com/automation-suite/2023.10.7+patch1/as-2023.10.7+patch1.tar.gz
    https://download.uipath.com/automation-suite/2023.10.7+patch1/as-2023.10.7+patch1-part-001
    https://download.uipath.com/automation-suite/2023.10.7+patch1/as-2023.10.7+patch1-part-002
as-fs.tar.gz
To download as-fs.tar.gz for Automation Suite 2023.10.7+patch1, run the following command:
wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2023.10.7+patch1/as-fs-2023.10.7+patch1.tar.gz
versions.json
To download versions.json for Automation Suite 2023.10.7+patch1, run the following command:
wget -O versions.json https://download.uipath.com/automation-suite/2023.10.7+patch1/versions.json
DU CJKOCR offline bundle
To download the DU CJKOCR offline bundle for 2023.10.7+patch1, refer to ML Packages Offline Installation.
2023.10.4 patches
This section provides the download links for the artifacts required for Automation Suite 2023.10.4 patches.
2023.10.4+patch3
as-images.txt
To download as-images.txt for Automation Suite 2023.10.4+patch3, run the following command:
wget -O as-images.txt https://download.uipath.com/automation-suite/2023.10.4+patch3/embedded-images.txt
as-helm-charts.txt
To download as-helm-charts.txt for Automation Suite 2023.10.4+patch3, run the following command:
wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.4+patch3/embedded-helm-charts.txt
mirror-registry.sh
To download mirror-registry.sh for Automation Suite 2023.10.4+patch3, run the following command:
wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.4+patch3/mirror-registry.sh
hydrate-registry.sh
To download hydrate-registry.sh for Automation Suite 2023.10.4+patch3, run the following command:
wget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.4+patch3/hydrate-registry.sh
as.tar.gz
To download as.tar.gz for Automation Suite 2023.10.4+patch3, take one of the following steps:
    wget -O as.tar.gz https://download.uipath.com/automation-suite/2023.10.4+patch3/as-2023.10.4+patch3.tar.gz
    https://download.uipath.com/automation-suite/2023.10.4+patch3/as-2023.10.4+patch3-part-001
as-fs.tar.gz
To download as-fs.tar.gz for Automation Suite 2023.10.4+patch3, run the following command:
wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2023.10.4+patch3/as-fs-2023.10.4+patch3.tar.gz
docker-images.json
To download docker-images.json for Automation Suite 2023.10.4+patch3, run the following command:
wget -O docker-images.json https://download.uipath.com/automation-suite/2023.10.4+patch3/docker-images.json
versions.json
To download versions.json for Automation Suite 2023.10.4+patch3 run the following command:
wget -O versions.json https://download.uipath.com/automation-suite/2023.10.4+patch3/versions.json
2023.10.4+patch2
as-images.txt
To download as-images.txt for Automation Suite 2023.10.4+patch2, run the following command:
wget -O as-images.txt https://download.uipath.com/automation-suite/2023.10.4+patch2/embedded-images.txt
as-helm-charts.txt
To download as-helm-charts.txt for Automation Suite 2023.10.4+patch2, run the following command:
wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.4+patch2/embedded-helm-charts.txt
mirror-registry.sh
To download mirror-registry.sh for Automation Suite 2023.10.4+patch2, run the following command:
wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.4+patch2/mirror-registry.sh
hydrate-registry.sh
To download hydrate-registry.sh for Automation Suite 2023.10.4+patch2, run the following command:
wget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.4+patch2/hydrate-registry.sh
as.tar.gz
To download as.tar.gz for Automation Suite 2023.10.4+patch2, take one of the following steps:
    wget -O as.tar.gz https://download.uipath.com/automation-suite/2023.10.4+patch2/as-2023.10.4+patch2.tar.gz
    https://download.uipath.com/automation-suite/2023.10.4+patch2/as-2023.10.4+patch2-part-001
    https://download.uipath.com/automation-suite/2023.10.4+patch2/as-2023.10.4+patch2-part-002
as-fs.tar.gz
To download as-fs.tar.gz for Automation Suite 2023.10.4+patch2, run the following command:
wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2023.10.4+patch2/as-fs-2023.10.4+patch2.tar.gz
docker-images.json
To download docker-images.json for Automation Suite 2023.10.4+patch2, run the following command:
wget -O docker-images.json https://download.uipath.com/automation-suite/2023.10.4+patch2/docker-images.json
versions.json
To download versions.json for Automation Suite 2023.10.4+patch2, run the following command:
wget -O versions.json https://download.uipath.com/automation-suite/2023.10.4+patch2/versions.json
2023.10.4+patch1
as-images.txt
To download as-images.txt for Automation Suite 2023.10.4+patch1, run the following command:
wget -O as-images.txt https://download.uipath.com/automation-suite/2023.10.4+patch1/embedded-images.txt
as-helm-charts.txt
To download as-helm-charts.txt for Automation Suite 2023.10.4+patch1, run the following command:
wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.4+patch1/embedded-helm-charts.txt
mirror-registry.sh
To download mirror-registry.sh for Automation Suite 2023.10.4+patch1, run the following command:
wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.4+patch1/mirror-registry.sh
hydrate-registry.sh
To download hydrate-registry.sh for Automation Suite 2023.10.4+patch1, run the following command:
wget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.4+patch1/hydrate-registry.sh
as.tar.gz
To download as.tar.gz for Automation Suite 2023.10.4+patch1, take one of the following steps:
    wget -O as.tar.gz https://download.uipath.com/automation-suite/2023.10.4+patch1/as-2023.10.4+patch1.tar.gz
    https://download.uipath.com/automation-suite/2023.10.4+patch1/as-2023.10.4+patch1-part-001
    https://download.uipath.com/automation-suite/2023.10.4+patch1/as-2023.10.4+patch1-part-002
as-fs.tar.gz
To download as-fs.tar.gz for Automation Suite 2023.10.4+patch1, run the following command:
wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2023.10.4+patch1/as-fs-2023.10.4+patch1.tar.gz
docker-images.json
To download docker-images.json for Automation Suite 2023.10.4+patch1, run the following command:
wget -O docker-images.json https://download.uipath.com/automation-suite/2023.10.4+patch1/docker-images.json
versions.json
To download versions.json for Automation Suite 2023.10.4+patch1, run the following command:
wget -O versions.json https://download.uipath.com/automation-suite/2023.10.4+patch1/versions.json
2023.10.3 patches
This section provides the download links for the artifacts required for Automation Suite 2023.10.3 patches.
2023.10.3+patch3
as-images.txt
To download as-images.txt for Automation Suite 2023.10.3+patch3, run the following command:
wget -O as-images.txt https://download.uipath.com/automation-suite/2023.10.3+patch3/embedded-images.txt
as-helm-charts.txt
To download as-helm-charts.txt for Automation Suite 2023.10.3+patch3, run the following command:
wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.3+patch3/embedded-helm-charts.txt
mirror-registry.sh
To download mirror-registry.sh for Automation Suite 2023.10.3+patch3, run the following command:
wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.3+patch3/mirror-registry.sh
hydrate-registry.sh
To download hydrate-registry.sh for Automation Suite 2023.10.3+patch3, run the following command:
wget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.3+patch3/hydrate-registry.sh
as.tar.gz
To download as.tar.gz for Automation Suite 2023.10.3+patch3, take one of the following steps:
    wget -O as.tar.gz https://download.uipath.com/automation-suite/2023.10.3+patch3/as-2023.10.3+patch3.tar.gz
    https://download.uipath.com/automation-suite/2023.10.3+patch3/as-2023.10.3+patch3-part-001
    https://download.uipath.com/automation-suite/2023.10.3+patch3/as-2023.10.3+patch3-part-002
as-fs.tar.gz
To download as-fs.tar.gz for Automation Suite 2023.10.3+patch3, run the following command:
wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2023.10.3+patch3/as-fs-2023.10.3+patch3.tar.gz
docker-images.json
To download docker-images.json for Automation Suite 2023.10.3+patch3, run the following command:
wget -O docker-images.json https://download.uipath.com/automation-suite/2023.10.3+patch3/docker-images.json
versions.json
To download versions.json for Automation Suite 2023.10.3+patch3, run the following command:
wget -O versions.json https://download.uipath.com/automation-suite/2023.10.3+patch3/versions.json
2023.10.3+patch2
We have removed the download links for the Automation Suite 2023.10.3+patch2 artifacts because the patch did not work as intended.
The fixes included in Automation Suite 2023.10.3+patch2 will also be available in Automation Suite 2023.10.3+patch3 and 2023.10.5. We recommend that you wait for Automation Suite 2023.10.5 to get the fixes.
2023.10.3+patch1
as-images.txt
To download as-images.txt for Automation Suite 2023.10.3+patch1, run the following command:
wget -O as-images.txt https://download.uipath.com/automation-suite/2023.10.3+patch1/embedded-images.txt
as-helm-charts.txt
To download as-helm-charts.txt for Automation Suite 2023.10.3+patch1, run the following command:
wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.3+patch1/embedded-helm-charts.txt
mirror-registry.sh
To download mirror-registry.sh for Automation Suite 2023.10.3+patch1, run the following command:
wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.3+patch1/mirror-registry.sh
hydrate-registry.sh
To download hydrate-registry.sh for Automation Suite 2023.10.3+patch1, run the following command:
wget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.3+patch1/hydrate-registry.sh
as.tar.gz
To download as.tar.gz for Automation Suite 2023.10.3+patch1, take one of the following steps:
    wget -O as.tar.gz https://download.uipath.com/automation-suite/2023.10.3+patch1/as-2023.10.3+patch1.tar.gz
    https://download.uipath.com/automation-suite/2023.10.3+patch1/as-2023.10.3+patch1-part-001
    https://download.uipath.com/automation-suite/2023.10.3+patch1/as-2023.10.3+patch1-part-002
    https://download.uipath.com/automation-suite/2023.10.3+patch1/as-2023.10.3+patch1-part-003
as-fs.tar.gz
To download as-fs.tar.gz for Automation Suite 2023.10.3+patch1, run the following command:
wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2023.10.3+patch1/as-fs-2023.10.3+patch1.tar.gz
docker-images.json
To download docker-images.json for Automation Suite 2023.10.3+patch1, run the following command:
wget -O docker-images.json https://download.uipath.com/automation-suite/2023.10.3+patch1/docker-images.json
versions.json
To download versions.json for Automation Suite 2023.10.3+patch1, run the following command:
wget -O versions.json https://download.uipath.com/automation-suite/2023.10.3+patch1/versions.json
2023.10.2 patches
This section provides the download links for the artifacts required for Automation Suite 2023.10.2 patches.
2023.10.2+patch5
as-images.txt
To download as-images.txt for Automation Suite 2023.10.2+patch5, run the following command:
wget -O as-images.txt https://download.uipath.com/automation-suite/2023.10.2+patch5/embedded-images.txt
as-helm-charts.txt
To download as-helm-charts.txt for Automation Suite 2023.10.2+patch5, run the following command:
wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.2+patch5/embedded-helm-charts.txt
mirror-registry.sh
To download mirror-registry.sh for Automation Suite 2023.10.2+patch5, run the following command:
wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.2+patch5/mirror-registry.sh
hydrate-registry.sh
To download hydrate-registry.sh for Automation Suite 2023.10.2+patch5, run the following command:
wget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.2+patch5/hydrate-registry.sh
as.tar.gz
To download as.tar.gz for Automation Suite 2023.10.2+patch5, take one of the following steps:
    wget -O as.tar.gz https://download.uipath.com/automation-suite/2023.10.2+patch5/as-2023.10.2+patch5.tar.gz
    https://download.uipath.com/automation-suite/2023.10.2+patch5/as-2023.10.2+patch5-part-001
    https://download.uipath.com/automation-suite/2023.10.2+patch5/as-2023.10.2+patch5-part-002
as-fs.tar.gz
To download as-fs.tar.gz for Automation Suite 2023.10.2+patch5, run the following command:
wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2023.10.2+patch5/as-fs-2023.10.2+patch5.tar.gz
docker-images.json
To download docker-images.json for Automation Suite 2023.10.2+patch5, run the following command:
wget -O docker-images.json https://download.uipath.com/automation-suite/2023.10.2+patch5/docker-images.json
versions.json
To download versions.json for Automation Suite 2023.10.2+patch5, run the following command:
wget -O versions.json https://download.uipath.com/automation-suite/2023.10.2+patch5/versions.json
2023.10.2+patch4
as-images.txt
To download as-images.txt for Automation Suite 2023.10.2+patch4, run the following command:
wget -O as-images.txt https://download.uipath.com/automation-suite/2023.10.2+patch4/embedded-images.txt
as-helm-charts.txt
To download as-helm-charts.txt for Automation Suite 2023.10.2+patch4, run the following command:
wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.2+patch4/embedded-helm-charts.txt
mirror-registry.sh
To download mirror-registry.sh for Automation Suite 2023.10.2+patch4, run the following command:
wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.2+patch4/mirror-registry.sh
hydrate-registry.sh
To download hydrate-registry.sh for Automation Suite 2023.10.2+patch4, run the following command:
wget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.2+patch4/hydrate-registry.sh
as.tar.gz
To download as.tar.gz for Automation Suite 2023.10.2+patch4, take one of the following steps:
    wget -O as.tar.gz https://download.uipath.com/automation-suite/2023.10.2+patch4/as-2023.10.2+patch4.tar.gz
    https://download.uipath.com/automation-suite/2023.10.2+patch4/as-2023.10.2+patch4-part-001
    https://download.uipath.com/automation-suite/2023.10.2+patch4/as-2023.10.2+patch4-part-002
    https://download.uipath.com/automation-suite/2023.10.2+patch4/as-2023.10.2+patch4-part-003
as-fs.tar.gz
To download as-fs.tar.gz for Automation Suite 2023.10.2+patch4, run the following command:
wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2023.10.2+patch4/as-fs-2023.10.2+patch4.tar.gz
docker-images.json
To download docker-images.json for Automation Suite 2023.10.2+patch4, run the following command:
wget -O docker-images.json https://download.uipath.com/automation-suite/2023.10.2+patch4/docker-images.json
versions.json
To download versions.json for Automation Suite 2023.10.2+patch4, run the following command:
wget -O versions.json https://download.uipath.com/automation-suite/2023.10.2+patch4/versions.json
2023.10.2+patch3
as-images.txt
To download as-images.txt for Automation Suite 2023.10.2+patch3, run the following command:
wget -O as-images.txt https://download.uipath.com/automation-suite/2023.10.2+patch3/embedded-images.txt
as-helm-charts.txt
To download as-helm-charts.txt for Automation Suite 2023.10.2+patch3, run the following command:
wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.2+patch3/embedded-helm-charts.txt
mirror-registry.sh
To download mirror-registry.sh for Automation Suite 2023.10.2+patch3, run the following command:
wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.2+patch3/mirror-registry.sh
hydrate-registry.sh
To download hydrate-registry.sh for Automation Suite 2023.10.2+patch3, run the following command:
wget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.2+patch3/hydrate-registry.sh
as.tar.gz
To download as.tar.gz for Automation Suite 2023.10.2+patch3, take one of the following steps:
    wget -O as.tar.gz https://download.uipath.com/automation-suite/2023.10.2+patch3/as-2023.10.2+patch3.tar.gz
    https://download.uipath.com/automation-suite/2023.10.2+patch3/as-2023.10.2+patch3-part-001
    https://download.uipath.com/automation-suite/2023.10.2+patch3/as-2023.10.2+patch3-part-002
as-fs.tar.gz
To download as-fs.tar.gz for Automation Suite 2023.10.2+patch3, run the following command:
wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2023.10.2+patch3/as-fs-2023.10.2+patch3.tar.gz
docker-images.json
To download docker-images.json for Automation Suite 2023.10.2+patch3, run the following command:
wget -O docker-images.json https://download.uipath.com/automation-suite/2023.10.2+patch3/docker-images.json
versions.json
To download versions.json for Automation Suite 2023.10.2+patch3, run the following command:
wget -O versions.json https://download.uipath.com/automation-suite/2023.10.2+patch3/versions.json
2023.10.2+patch2
as-images.txt
To download as-images.txt for Automation Suite 2023.10.2+patch2, run the following command:
wget -O as-images.txt https://download.uipath.com/automation-suite/2023.10.2+patch2/embedded-images.txt
as-helm-charts.txt
To download as-helm-charts.txt for Automation Suite 2023.10.2+patch2, run the following command:
wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.2+patch2/embedded-helm-charts.txt
mirror-registry.sh
To download mirror-registry.sh for Automation Suite 2023.10.2+patch2, run the following command:
wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.2+patch2/mirror-registry.sh
hydrate-registry.sh
To download hydrate-registry.sh for Automation Suite 2023.10.2+patch2, run the following command:
wget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.2+patch2/hydrate-registry.sh
as.tar.gz
To download as.tar.gz for Automation Suite 2023.10.2+patch2, take one of the following steps:
    wget -O as.tar.gz https://download.uipath.com/automation-suite/2023.10.2+patch2/as-2023.10.2+patch2.tar.gz
    https://download.uipath.com/automation-suite/2023.10.2+patch2/as-2023.10.2+patch2-part-001
    https://download.uipath.com/automation-suite/2023.10.2+patch2/as-2023.10.2+patch2-part-002
as-fs.tar.gz
To download as-fs.tar.gz for Automation Suite 2023.10.2+patch2, run the following command:
wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2023.10.2+patch2/as-fs-2023.10.2+patch2.tar.gz
docker-images.json
To download docker-images.json for Automation Suite 2023.10.2+patch2, run the following command:
wget -O docker-images.json https://download.uipath.com/automation-suite/2023.10.2+patch2/docker-images.json
versions.json
To download versions.json for Automation Suite 2023.10.2+patch2, run the following command:
wget -O versions.json https://download.uipath.com/automation-suite/2023.10.2+patch2/versions.json
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
