Migrating from Canal to Cilium CNI
Important:
  • This step is only required when performing a manual upgrade from Automation Suite 2021.10.
  • To reduce the time required for a Canal to Cilium migration, you can skip the prerequisite check when running install-uipath.sh using the -- skip-pre-reqs parameter.
Online​
To migrate from Canal to Cilium, take the following steps on all the machines in the cluster. Make sure to perform this operation on one node at a time.
  1. To migrate, run the following command:
    ./install-uipath.sh --upgrade -c -i ./cluster_config.json -o ./output.json --accept-license-agreement
  2. Reboot the node using the reboot command or any other safe reboot method you may prefer.
Offline​
To migrate Canal to Cilium, take the following steps on all the machines in the cluster. Make sure to perform this operation on one node at a time.
    ./install-uipath.sh --upgrade -c -i ./cluster_config.json -o ./output.json --offline-bundle ../sf-infra.tar.gz --offline-tmp-folder /opt/UiPathAutomationSuite/tmp --accept-license-agreement
  • Online​
  • Offline​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
