- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
While installing or upgrading Automation Suite, if the any pods cannot mount to the PVC pods, the following error message is displayed:
UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY
Recovery steps
If you encounter the error above, follow the recovery steps below:
SSH to the system by running the following command:
ssh <user>@<node-ip>ssh <user>@<node-ip> -
Check the events of the PVC and verify that the issue is related to the PVC mount failure due to file error. To do this, run the following command:
export KUBECONFIG=/etc/rancher/rke2/rke2.yaml PATH=$PATH:/var/lib/rancher/rke2/bin:/usr/local/bin kubectl get events -n mongodb kubectl get events -n longhorn-systemexport KUBECONFIG=/etc/rancher/rke2/rke2.yaml PATH=$PATH:/var/lib/rancher/rke2/bin:/usr/local/bin kubectl get events -n mongodb kubectl get events -n longhorn-system -
Check the PVC volume mentioned in the event and run the
fsckcommand.fsck -a <pvc-volume-name> Eg - fsck -a /dev/longhorn/pvc-5abe3c8f-7422-44da-9132-92be5641150afsck -a <pvc-volume-name> Eg - fsck -a /dev/longhorn/pvc-5abe3c8f-7422-44da-9132-92be5641150a -
Delete the failing MongoDB pod to properly mount it to the PVC.
kubectl delete pod <pod-name> -n mongodbkubectl delete pod <pod-name> -n mongodb
