- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
The prerequisite check for
selinux iscsid module might fail in the following scenarios:
selinux iscsid module fails with the following error:
Validating Selinux iscsid module... STARTED
[WARN] [2023-06-08T11:02:36+0000]: Selinux module uipath-iscsid-dac is not installed
[INFO] [2023-06-08T11:02:36+0000]: Installing uipath-iscsid-dac selinux module
libsemanage.semanage_get_lock: Could not get direct transaction lock at /var/lib/selinux/targeted/semanage.trans.LOCK. (Resource temporarily unavailable).
semodule: Failed on /opt/UiPathAutomationSuite/UiPath_Installer/Prerequisite_Checks/hardware-validation/uipath-iscsid-dac.pp!
>>> [FAILED] Validating selinux policy for iscsid failed as module uipath-iscsid-dac is not loaded
* Installation of iscsid selinux module failed.
* Please follow our troubleshooting guide for more details.
Validating Selinux iscsid module... DONE
>>> [FAILED] One or more installation readiness checks are failed
---Validating Selinux iscsid module... STARTED
---Solution
To fix this issue, rerun the
validateUiPathASReadiness.sh script.
selinux iscsid module fails due to permission issues.
Solution
To fix this issue, apply the policy manually by running the following command:
cd Prerequisite_Checks/hardware-validation
checkmodule -M -m -o uipath-iscsid-dac.mod uipath-iscsid-dac.te
semodule_package -o uipath-iscsid-dac.pp -m uipath-iscsid-dac.mod
semodule -X 300 -i uipath-iscsid-dac.ppcd Prerequisite_Checks/hardware-validation
