Last updated Apr 2, 2025
Step 1: Removing old Identity cache keys
To remove the old Identity cache keys, take the following steps:
  1. To retrieve the Redis password, run the following command:
    kubectl --kubeconfig kubeconfig get secrets/redb-redis-cluster-db -n uipath --template '{{ .data.password }}'kubectl --kubeconfig kubeconfig get secrets/redb-redis-cluster-db -n uipath --template '{{ .data.password }}'
  2. To retrieve the Redis port, run the following command:
    kubectl --kubeconfig kubeconfig get secrets/redb-redis-cluster-db -n uipath --template '{{ .data.port }}'kubectl --kubeconfig kubeconfig get secrets/redb-redis-cluster-db -n uipath --template '{{ .data.port }}'
  3. To access the Redis node, run the following commnad:
    kubectl --kubeconfig kubeconfig exec -i -t -n redis-system redis-master-0 -c redis "--" sh -c "clear; (bash || ash || sh)"kubectl --kubeconfig kubeconfig exec -i -t -n redis-system redis-master-0 -c redis "--" sh -c "clear; (bash || ash || sh)"
  4. To delete the old keys, use the retrieved password and port and run the following command:
    redis-cli -p <Port number> -a <Password> --scan --pattern is:* | while read key; do redis-cli -p <Port number> -a <Password> del "$key"; doneredis-cli -p <Port number> -a <Password> --scan --pattern is:* | while read key; do redis-cli -p <Port number> -a <Password> del "$key"; done
  5. To end the session, run the exit command.
