- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
In a multi-node HA-ready production setup, High Availability (HA) is enabled by default. However, the Redis-based in-memory cache used by cluster services runs on a single node and represents a single point of failure. Therefore, if you have not purchased a High Availability Add-on (HAA) license, a cache node failure or restart will result in downtime for the entire cluster. To prevent such an incident, you can purchase HAA, which enables redundant, multi-node HA-ready production deployment of the cache.
All installations include the HAA software with a single-node license. This license is free of cost, no purchase required.
If you wish to enable HAA across multiple nodes, then purchasing an HAA license is required. This will implement full high availability for the cluster in a multi-node HA-ready production setup.
HAA is based on Redis technology.
To do that, take the following steps:
- Purchase an HAA license. Contact UiPath for details.
- Update the following fields in the
cluster_config.jsonfile:-
fabric.redis.license- enter the HAA license converted to a single base64 string. In bash you can do that usingecho 'license_text_here' | base64 -w0. -
fabric.redis.ha- usetrueto enable HAA and make sure to also configure thefabric.redis.licenseparameter. This enables HAA database replication and increases the number of HAA pods to 3. By default,fabric.redis.hais set tofalse.Note:If
redis.hais enabled,redis.licenseneeds to be set to a license that supports more than two shards."fabric": { "redis": { "ha": "true", "license": Base64String } }"fabric": { "redis": { "ha": "true", "license": Base64String } }
- Rerun the fabric installer:
Online installation
./install-uipath.sh -i cluster_config.json -f -o output.json --accept-license-agreement./install-uipath.sh -i cluster_config.json -f -o output.json --accept-license-agreement -
./install-uipath.sh -i cluster_config.json -f --install-type offline -o output.json --accept-license-agreement./install-uipath.sh -i cluster_config.json -f --install-type offline -o output.json --accept-license-agreement
Updating the Redis license
To update the Redis license, take the following steps:
Set up kubectl and ArgoCD access:
- Enable kubectl access on the primary node. See Enabling kubectl for instructions.
- Enable access to ArgoCD. See Accessing ArgoCD for instructions.
Check the current license status:
To check the status of the current license, run the following Shell command:
kubectl get rec -n redis-system redis-cluster -o jsonpath='{.status.licenseStatus}' | jqkubectl get rec -n redis-system redis-cluster -o jsonpath='{.status.licenseStatus}' | jq-
Clusters deployed after the expiry date of the license included in the installer will show the trial 4-shard license that expires in 30 days, as in the following example:
Clusters that were already running when the license expired will show the following status:
Update the existing license:
To update the existing license, run the following Shell command:
kubectl patch application fabric-installer -n argocd \ --type=json -p '[{"op":"add","path":"/spec/source/helm/parameters/-","value":{"name": "global.redis.license", "value": "<LICENSE_KEY_IN_BASE64>"}}]'kubectl patch application fabric-installer -n argocd \ --type=json -p '[{"op":"add","path":"/spec/source/helm/parameters/-","value":{"name": "global.redis.license", "value": "<LICENSE_KEY_IN_BASE64>"}}]' -
To see if the change was applied, access ArgoCD. See Accessing ArgoCD for instructions.
If the fabric-installer application appears out of sync, and the sync process was not triggered automatically, select the Sync button yourself. This may be happen if you are using an older Automation Suite version.
Note:There is a small delay between the moment the ArgoCD UI shows the app synced and when the Redis operator successfully applies the new license.
To see logs from the Redis operator when it tries to apply the license, run the following command:
kubectl logs -n redis-system --since=300s -l name=redis-enterprise-operator -c redis-enterprise-operator --tail=-1 | grep licensekubectl logs -n redis-system --since=300s -l name=redis-enterprise-operator -c redis-enterprise-operator --tail=-1 | grep license -
If you try to apply an expired license, or you run the installer that ships with an expired license, you will get the following output:
To update the Redis license used by older installers before running them, update the
fabric.redis.licensekey in the<installer_folder>/defaults.json:
Check that the new license is applied:
To check if the new license is applied, run the following Shell command:
kubectl get rec -n redis-system redis-cluster -o jsonpath='{.status.licenseStatus}' | jqkubectl get rec -n redis-system redis-cluster -o jsonpath='{.status.licenseStatus}' | jqIn the following image you can see that the Redis cluster switched from the trial 30-day license to a single-shard 10-year license.
