- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Orchestrator pod in CrashLoopBackOff or restarts multiple times
- Exploring Logs
Last updated Apr 2, 2025
If the Orchestrator pod is in CrashLoopBackOff or 1/2 is running with multiple restarts, the failure could be related to the authentication keys for the object storage provider, Ceph.
To check if the failure is related to Ceph, run the following commands:
kubectl -n uipath get pod -l app.kubernetes.io/component=orchestrator
If the output of this command is similar to one of the following options, you need to run an additional command.
Option 1:
NAME READY STATUS RESTARTS AGE
orchestrator-6dc848b7d5-q5c2q 1/2 Running 2 6m1s
OR
Option 2
orchestrator-6dc848b7d5-q5c2q 1/2 CrashLoopBackOff 6 16m
Option 1:
OR
Option 2
Verify if the failure is related to Ceph authentication keys by running the following command:
kubectl -n uipath logs -l app.kubernetes.io/component=orchestrator | grep 'Error making request with Error Code InvalidAccessKeyId and Http Status Code Forbidden' -o
If the output of the previous command contains the string
, the failure is due to the Ceph authentication keys.
Rerun the
rook-ceph-configure-script-job
and credential-manager
jobs using the following commands:
kubectl -n uipath-infra get job "rook-ceph-configure-script-job" -o json | jq 'del(. | .spec.selector, .spec.template.metadata.labels)' | kubectl replace --force -f -
kubectl -n uipath-infra get job "credential-manager-job" -o json | jq 'del(. | .spec.selector, .spec.template.metadata.labels)' | kubectl replace --force -f -
kubectl -n uipath delete pod -l app.kubernetes.io/component=orchestrator
