RKE2 server fails to start
Description​
The server fails to start. There are a few different reasons for RKE2 not starting properly, which are usually found in the logs.
Solution​
Check the logs using the following commands:
journalctl -u rke2-server
Possible reasons (based on logs): too many learner members in cluster
Too many etcd servers are added to the cluster, and there are two learner nodes trying to be promoted. More information here: Runtime reconfiguration.
Perform the following:
  1. Under normal circumstances, the node should become a full member if enough time is allowed.
  2. An uninstall-reinstall cycle can be attempted.
Alternatively, this could be caused by a networking problem. Ensure you have configured the machine to enable the necessary ports.
  • Description​
  • Solution​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
