- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Last updated Nov 6, 2025
When upgrading to Automation Suite 2022.10 and migrating your data to Azure external storage, RKE2 might experience some issues.
Specifically, rke2 might not get started and might fail with the following error message:
Failed to reconcile with temporary etcd: write /var/lib/rancher/rke2/server/db/etcd-tmp/member/snap/db: no space left on device.
To fix this issue, take the following steps:
Stop the SSSD service:
systemctl stop sssdsystemctl stop sssd -
Remove the SSSD logs:
rm /var/log/sssd/*rm /var/log/sssd/* -
Start the SSSD service:
systemctl start sssdsystemctl start sssd - We recommend changing the log rotate policy for the SSSD service from weekly to daily.
- If the error message persists, try rebooting the host.
