- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Step 1: Saving the connection strings
- Step 2: Creating your organizations in Automation Suite
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Save the following information for further usage:
The connection string for the Orchestrator database in the standalone deployment;
- The
test-automationdatabase connection string.
- The
The connection string for the Insights database in the standalone deployment;
AutomationSuite_Platformdatabase in the Automation Suite deployment. You can retrieve the connection string from thecluster_config.jsonfile, under theplatformparameter. -
The following Test Manager information from the
appsettings.production.jsonfile located in the Test Manager installation directory:Note:If the
appsettings.production.jsonfile is encrypted, you can use the Test Manager provisioning tool to decrypt it. For more information, visit Test Manager config file encryption.-
The connection string for the Test Manager database in the standalone deployment.
You can find the connection string in the following key:
Database.ConnectionString.testmanagementhub. -
The storage location information stored in the
Storage.Locationkey. -
The information stored in the
Security.DataEncryptionKeykey.
