- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Resizing PVC
Resizing Objectstore PVC
Resizing the PVC is required only if you upgraded to Automation Suite 2022.10 and did not migrate your Objectstore to raw disks.
To view more information about Objectstore, run the following command:
sudo ./configureUiPathAS.sh objectstore --help
Output
Manage objectstore configuration
Usage:
configureUiPathAS.sh objectstore [command]
configureUiPathAS.sh objectstore [flags]
Available Commands:
resize-pvc Resize PVC
Flags:
-h|--help Display help
Usage:
Available Commands:
Flags:
PVC resize can be dangerous and will result in downtime of entire or few of the effect components of cluster. Take caution before performing this operation.
To view more information about resizing Objectstore PVC, run the following command:
sudo ./configureUiPathAS.sh objectstore resize-pvc --help
The command returns the following output:
Resize PVC provided by different CSI drivers
Arguments
-s|--size [Required] : Size of PVC. Allowed formats are
- Plain integer
- A fixed-point number using one of these suffixes: E, P, T, G, M, k
- A fixed-point number using one of power-of-two equivalents suffixes: Ei, Pi, Ti, Gi, Mi, Ki
-b|--sub-component [Required] : Sub-component to resize. Possible Values [mon|data]
-d|--debug Increase logging verbosity to show all debug logs
-h|--help Show this help message and exit
-f|--force Allow deletion of pods to resize the PVC. This may cause downtime
Examples
Update PVC size for objectstore mon to 105 Gi
configureUiPathAS.sh objectstore resize-pvc --size 105Gi --sub-component "mon"
Arguments
- Plain integer
Examples
To resize the data storage of Ceph Objectstore, run the following command:
sudo ./configureUiPathAS.sh objectstore resize-pvc --size 1024Gi --sub-component data
The command resizes the data storage PVC to 1 TiB.
Before starting the PVC resize operation, tool warns you about the impact. You must accept and only then proceed. You can also use --force flag to skip the warning.
If the attempt to resize the objstore pvc operation failed, see the Troubleshooting section for a fix.
Resizing rabbitmq PVC
To view more information about resizing rabbitmq PVC, run the following command:
sudo ./configureUiPathAS.sh rabbitmq resize-pvc --help
Arguments
- Plain integer
-b|--sub-component [Required] : Sub-component to resize. Possible Values [server]
Examples
Update PVC size for rabbitmq server to 105 Gi
configureUiPathAS.sh rabbitmq resize-pvc --size 105Gi --sub-component "server"
Arguments
- Plain integer
Examples
To resize the rabbitmq PVC, run the following command:
sudo ./configureUiPathAS.sh rabbitmq resize-pvc --size 100Gi --sub-component "server"
Resizing mongodb PVC
To view more information about resizing mongodb PVC, run the following command:
sudo ./configureUiPathAS.sh mongodb resize-pvc --help
Arguments
- Plain integer
-b|--sub-component [Required] : Sub-component to resize. Possible Values [data|logs]
Examples
Update PVC size for mongodb data to 105 Gi
configureUiPathAS.sh mongodb resize-pvc --size 105Gi --sub-component "data"
Arguments
- Plain integer
Examples
To resize the mongodb PVC, run the following command:
sudo ./configureUiPathAS.sh mongodb resize-pvc --size 105Gi --sub-component "data"
The command resizes the data PVC of mongodb. If you want to resize the logs pvc, you must use --sub-component "logs".
Resizing monitoring PVC
To view more information about resizing monitoring PVC, run the following command:
sudo ./configureUiPathAS.sh monitoring resize-pvc --help
Arguments
- Plain integer
-b|--sub-component [Required] : Sub-component to resize. Possible Values [alertmanager|prometheus]
Examples
Update PVC size for monitoring alertmanager to 105 Gi
configureUiPathAS.sh monitoring resize-pvc --size 105Gi --sub-component "alertmanager"
Arguments
- Plain integer
Examples
To resize the monitoring PVC, run the following command:
sudo ./configureUiPathAS.sh monitoring resize-pvc --size 100Gi --sub-component "alertmanager"
You can resize prometheus PVC by passing the value prometheus to the --sub-component argument.
Resizing registry PVC
To view more information about resizing registry PVC, run the following command:
sudo ./configureUiPathAS.sh registry resize-pvc --help
Arguments
- Plain integer
-b|--sub-component [Required] : Sub-component to resize. Possible Values [data]
Examples
Update PVC size for registry data to 105 Gi
configureUiPathAS.sh registry resize-pvc --size 105Gi --sub-component "data"
Arguments
- Plain integer
Examples
To resize the registry PVC, run the following command:
sudo ./configureUiPathAS.sh registry resize-pvc --size 100Gi --sub-component "data"
