- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
This issue occurs when the objectstore resize-pvc operation fails with the following error:
Failed resizing the PVC: <pvc name> in namespace: rook-ceph, ROLLING BACK
Solution
To fix this problem, take the following steps:
Run the following script manually:
#!/bin/sh ROOK_CEPH_OSD_PREPARE=$(kubectl -n rook-ceph get pods | grep rook-ceph-osd-prepare-set | awk '{print $1}') if [[ -n ${ROOK_CEPH_OSD_PREPARE} ]]; then for pod in ${ROOK_CEPH_OSD_PREPARE}; do echo "Start deleting rook ceph osd pod $pod .." kubectl -n rook-ceph delete pod $pod echo "Done" done; fi#!/bin/sh ROOK_CEPH_OSD_PREPARE=$(kubectl -n rook-ceph get pods | grep rook-ceph-osd-prepare-set | awk '{print $1}') if [[ -n ${ROOK_CEPH_OSD_PREPARE} ]]; then for pod in ${ROOK_CEPH_OSD_PREPARE}; do echo "Start deleting rook ceph osd pod $pod .." kubectl -n rook-ceph delete pod $pod echo "Done" done; fi -
Rerun the
objectstore resize-pvccommand.
