- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Accessing Automation Suite
- Managing the Certificates
- Resizing PVC
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Before running any kubectl commands, make sure to enable kubectl. This allows you to run commands for retrieving passwords and configuration details for the cluster.
To enable kubectl, run the following command:
sudo su -
export KUBECONFIG="/etc/rancher/rke2/rke2.yaml" \
&& export PATH="$PATH:/usr/local/bin:/var/lib/rancher/rke2/bin"sudo su -
&& export PATH="$PATH:/usr/local/bin:/var/lib/rancher/rke2/bin"The installation process generates self-signed certificates on your behalf. These certificates will expire in 90 days, and you must replace them with certificates signed by a trusted Certificate Authority (CA) as soon as installation completes. If you do not update the certificates, the installation will stop working after 90 days.
For instructions, see Managing certificates.
If you try to access the cluster with a web browser, and the certificates are not from a trusted CA, then you will see a warning in the browser. You can rectify this by importing and trusting the cluster SSL certificate on the client computer running the browser.
To manage certificates, take the following steps:
The Cluster Administration portal is a centralized location where you can find all the resources required to complete an Automation Suite installation and perform common post-installation operations. For details, see Getting started with the Cluster Administration portal.
To access the Cluster Administration portal, take the following step:
https://${CONFIG_CLUSTER_FQDN}/uipath-management.The general-use Automation Suite user interface serves as a portal for both organization administrators and organization users. It is a common organization-level resource from where everyone can access all of your Automation Suite areas: administration pages, platform-level pages, product-specific pages, and user-specific pages.
To access Automation Suite, take the following steps:
The host portal is for system administrators to configure the Automation Suite instance. The settings that you configure from this portal are inherited by all your organizations, and some can be overwritten at the organization level.
To access host administration, take the following steps:
You can use the ArgoCD console to manage installed products.
Depending on the operations you want to carry out in ArgoCD, you can use two types of accounts to access the console:
- the read-only account in basic scenarios
- admin account in advanced scenarios
For more details on ArgoCD and how you can access it, see Managing the cluster in ArgoCD.
Automation Suite uses Rancher to provide cluster management tools out of the box. This helps you manage the cluster and access monitoring and troubleshooting.
See Rancher documentation for more details.
See Using the monitoring stack for more on how to use Rancher monitoring in Automation Suite.
To access the Rancher console, take the following steps:
You can access the database connection strings for each service as follows:
kubectl -n uipath get secret aicenter-secrets -o jsonpath='{.data.sqlConnectionString}' | base64 --decode
kubectl -n uipath get secret orchestrator-secrets -o jsonpath='{.data.sqlConnectionString}' | base64 --decode
kubectl -n uipath get secret automation-hub-secrets -o jsonpath='{.data.sqlConnectionString}' | base64 --decode
kubectl -n uipath get secret automation-ops-secrets -o jsonpath='{.data.sqlConnectionString}' | base64 --decode
kubectl -n uipath get secret insights-secrets -o jsonpath='{.data.sqlConnectionString}' | base64 --decode
kubectl -n uipath get secret platform-service-secrets -o jsonpath='{.data.sqlConnectionString}' | base64 --decode
kubectl -n uipath get secret test-manager-secrets -o jsonpath='{.data.sqlConnectionString}' | base64 --decodekubectl -n uipath get secret aicenter-secrets -o jsonpath='{.data.sqlConnectionString}' | base64 --decode
