- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Moving Ceph out of read-only mode
If you installed AI Center and use Ceph storage, take the following steps to move Ceph out of read-only mode:
Disabling streaming logs
To ensure everything is in a good state, disable streaming logs by taking the following steps.
If you use an s3-compatible storage provider, take the following steps to clean up your logs:
To clean up logs automatically, you can also configure a cleanup policy on your external object store.
Note:
The following example shows the steps needed for AWS:
CORS and bucket retention policy are subject to change based on the ObjectStore provider. Refer to your ObjectStore provider documentation for the same.
We recommend retention of 15 days for the logs generated by the Automation Suite platform. These log objects are found in
the
automation-suite-logs folder of the platform bucket.
- Create
policy.jsonwith the following content:{ "Rules": [ { "Filter": { "Prefix": "automation-suite-logs/" }, "Status": "Enabled", "Expiration": { "Days": 15 }, "ID": "DeleteOldLogs" } ] }{ "Rules": [ { "Filter": { "Prefix": "automation-suite-logs/" }, "Status": "Enabled", "Expiration": { "Days": 15 }, "ID": "DeleteOldLogs" } ] } - To apply
policy.jsonto the bucket, run the following command:aws s3api put-bucket-lifecycle-configuration --bucket BUCKET_NAME --lifecycle-configuration file://policy.jsonaws s3api put-bucket-lifecycle-configuration --bucket BUCKET_NAME --lifecycle-configuration file://policy.json
