- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Accessing Automation Suite
- Managing the Certificates
- Resizing PVC
- Updating the SQL connection strings
- Updating objectstore credentials
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Generating the cluster_config.json file
Generate the latest cluster_config.json file as follows:
A: If you have the old
cluster_config.json, generate the configuration file from the cluster using the following command:cd /opt/UiPathAutomationSuite/{version}/installer ./configureUiPathAS.sh config get -i /path/to/old/cluster_config.json -o ./cluster_config.jsoncd /opt/UiPathAutomationSuite/{version}/installer ./configureUiPathAS.sh config get -i /path/to/old/cluster_config.json -o ./cluster_config.json -
B: If you do not have the old
cluster_config.jsonfile, generate an override of any default values resulted during the installation of the previous version using the following command:cd /opt/UiPathAutomationSuite/{version}/installer ./configureUiPathAS.sh config get -o ./cluster_config.jsoncd /opt/UiPathAutomationSuite/{version}/installer ./configureUiPathAS.sh config get -o ./cluster_config.json
For details on how to configure the cluster_config.json parameters, see Advanced installation experience.
Providing the new credentials
Update the following section in the cluster_config.json file with the new access_key, secret_key or acount_key and account_name:
"external_object_storage": {
"enabled": false, // <true/false>
"create_bucket": true, // <true/false>
"storage_type": "s3", // <s3,azure,aws>
"fqdn": "", // <needed in case of aws non instance profile>
"port": 443, // <needed in case of aws non instance profile>
"region": "",
"access_key": "", // <needed in case of aws non instance profile>
"secret_key": "", // <needed in case of aws non instance profile>
"use_managed_identity": false, // <true/false>
"bucket_name_prefix": "",
"bucket_name_suffix": "",
"account_key": "", // <needed only when using non managed identity>
"account_name": "",
"azure_fqdn_suffix": "core.windows.net",
"client_id": "" // <optional field in case of managed identity>
"region": "",
"account_name": "",
Running the service installer
Online
To run the service installer in an online environment, use the following command:
./install-uipath.sh -i ./cluster_config.json -s -o output.json --accept-license-agreement
Offline
To run the service installer in an offline environment, use the following command:
./install-uipath.sh -i ./cluster_config.json -s --install-type offline -o output.json --accept-license-agreement
