- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Navigating to Insights homepage generates a 404
- Looker fails to initialize
- Exploring Logs
Last updated Jun 30, 2025
During Looker initialization, you might encounter and error stating
RuntimeError: Error starting Looker. A Looker pod failure produced this error due to a possible system failure or loss of power. The issue is persistent even
if you reinitialize Looker.
To solve this issue, delete the persistent volume claim (PVC) and then restart.
