- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Remapping the organization IDs
- Migrating Looker data to Automation Suite
- Performing Insights database maintenance
- Configuring log rules
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
To migrate from standalone Insights to Automation Suite, you must remap of the organization IDs in the following tables:
[Id] [int] NOT NULL,
[Key] [nvarchar](128) NOT NULL,
[Name] [nvarchar](128) NOT NULL,
[IsActive] [bit] NOT NULL,
[IsDeleted] [bit] NOT NULL,
[OrganizationId] [nvarchar](128) NULL,
CONSTRAINT [PK_dbo.Tenants] PRIMARY KEY CLUSTERED
CREATE TABLE [insightsintegrations].[TenantServiceIntegrations](
[Id] [uniqueidentifier] NOT NULL,
[TenantId] [uniqueidentifier] NOT NULL,
[OrganizationId] [uniqueidentifier] NOT NULL,
[ServiceName] [int] NOT NULL,
[Status] [int] NOT NULL,
[CreationTime] [datetime2](7) NOT NULL,
[LastUpdatetime] [datetime2](7) NOT NULL,
CONSTRAINT [PK_TenantServiceIntegrations] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[GroupRoles](
[GroupId] [uniqueidentifier] NOT NULL,
[RoleId] [uniqueidentifier] NOT NULL,
CONSTRAINT [PK_GroupRoles] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[Groups](
[Name] [nvarchar](max) NULL,
[Email] [nvarchar](max) NULL,
CONSTRAINT [PK_Groups] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[Roles](
[TenantId] [uniqueidentifier] NULL,
[Resource] [nvarchar](max) NULL,
CONSTRAINT [PK_Roles] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[TenantGroups](
[TimeProcessed] [datetime2](7) NULL,
[LastUpdateTime] [datetime2](7) NOT NULL,
CONSTRAINT [PK_TenantGroup] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[Tenants](
CONSTRAINT [PK_Tenants] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[Users](
[IsDeleted] [bit] NULL,
CONSTRAINT [PK_Users] PRIMARY KEY CLUSTERED
CREATE TABLE [insightsprovisioning].[TenantInstances](
[ServiceType] [nvarchar](max) NULL,
[State] [int] NOT NULL,
[TenantName] [nvarchar](max) NULL,
CONSTRAINT [PK_TenantInstances] PRIMARY KEY CLUSTERED
CREATE TABLE [read].[HASHKEYS](
[hashkey] [bigint] NOT NULL,
[tenantkey] [nvarchar](128) NOT NULL,
[tenantname] [nvarchar](256) NULL,
[organizationid] [nvarchar](128) NULL,
[status] [int] NULL
[status] [int] NULL
)[dbo].[Tenants]
[read].[HASHKEYS][dbo].[Tenants]
[read].[HASHKEYS]Tip: This is an example on how to update the tables:
--- Script to replace MSI organization ID with AS organization ID.
--- Please update the following DECLARE statements with your corresponding MSI org ID and AS org ID before executing this script.
DECLARE @msi_organization_id nvarchar(500) = upper('687db434-ce5c-4058-bc0b-3ed3fa23882b');
DECLARE @as_organization_id nvarchar(500) = upper('AA259F1A-5828-4608-AF71-27177A7831B8');
DECLARE @msi_resource nvarchar(500) = lower('insights/687db434-ce5c-4058-bc0b-3ed3fa23882b/687db434-ce5c-4058-bc0b-3ed3fa23882b/*');
DECLARE @as_resource nvarchar(500) = lower('insights/aa259f1a-5828-4608-af71-27177a7831b8/687db434-ce5c-4058-bc0b-3ed3fa23882b/*');
SELECT * FROM [dbo].[Tenants];
UPDATE [dbo].[Tenants]
SET OrganizationId = lower(@as_organization_id)
WHERE OrganizationId = lower(@msi_organization_id);
SELECT * FROM [insightsintegrations].[TenantServiceIntegrations];
UPDATE [insightsintegrations].[TenantServiceIntegrations]
SET OrganizationId = @as_organization_id
WHERE OrganizationId = @msi_organization_id;
ALTER TABLE [insightspermissions].[GroupRoles] NOCHECK CONSTRAINT FK_GroupRoles_Groups_GroupId_OrganizationId;
SELECT * FROM [insightspermissions].[GroupRoles];
UPDATE [insightspermissions].[GroupRoles]
ALTER TABLE [insightspermissions].[GroupRoles] CHECK CONSTRAINT FK_GroupRoles_Groups_GroupId_OrganizationId;
ALTER TABLE [insightspermissions].[TenantGroups] NOCHECK CONSTRAINT FK_TenantGroups_Groups_GroupId_OrganizationId;
SELECT * FROM [insightspermissions].[TenantGroups];
UPDATE [insightspermissions].[TenantGroups]
ALTER TABLE [insightspermissions].[TenantGroups] CHECK CONSTRAINT FK_TenantGroups_Groups_GroupId_OrganizationId;
SELECT * FROM [insightspermissions].[Groups];
UPDATE [insightspermissions].[Groups]
SELECT * FROM [insightspermissions].[Roles];
UPDATE [insightspermissions].[Roles]
SET Resource = @as_resource
WHERE Resource = @msi_resource;
SELECT * FROM [insightspermissions].[Tenants];
UPDATE [insightspermissions].[Tenants]
SELECT * FROM [insightspermissions].[Users];
UPDATE [insightspermissions].[Users]
SELECT * FROM [insightsprovisioning].[TenantInstances];
UPDATE [insightsprovisioning].[TenantInstances]
SELECT * FROM [read].[HASHKEYS];
UPDATE [read].[HASHKEYS]
WHERE OrganizationId = @msi_organization_id;--- Script to replace MSI organization ID with AS organization ID.
