- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
SQL validation fails during upgrade
When trying to upgrade to a new Automation Suite version, validateUiPathASReadiness.sh can fail to validate SQL connectivity.
The validateUiPathASReadiness.sh script uses the podman command to run containers to verify the SQL connection.
If there is any corruption in the Podman system data, the podman command can fail to run and, consequently, can cause the validateUiPathASReadiness.sh execution to fail also.
Solution
You can verify if there is any Podman data corruption by running the podman volume ls or podman secret ls command. If the previous commands fail, you can reset the Podman files by running the podman system reset command.
The podman system reset command stops all Podman containers and removes all images, volumes, networks, and container content.
