Cross-deployment feature comparison
This table compares the feature availability across the following deployment methods:
  • the AWS, Azure, and GCP cloud templates, which provision the infrastructure and install Automation Suite in a short amount of time. Templates are the recommended option.
  • the manual installation provisioning method, which requires more technical expertise and is considerably more time-consuming.
    FeatureAWS templateAzure templateGCP templateManual installation provisioning
    Deploy to existing Virtual Network✅✅❌✅
    Single-node evaluation vs. multi-node HA-ready production✅✅
    Can set number of instances
    Air-gapped❌❌❌✅
    A-la-carte product selection✅✅✅✅
    Custom domain (cloud-provided DNS service or not)✅✅✅✅
    Custom certificates✅✅❌✅
    Deploy to existing SQL Server❌✅❌✅
    Hardware requirements validation✅✅❌✅
    Template uses cloud-native availability zones✅✅✅N/A
    Proxy configuration❌❌❌✅
    Optional bastion host✅✅❌N/A
    Instance refresh❌✅❌N/A
    Backup and restore cluster✅✅❌N/A
    Remove nodes✅✅❌N/A
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
