- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
In certain situations, Prometheus pods can fail to start due to an out-of-memory (OOM) error. To identify the affected Prometheus pods, search for the last termination state that specifically relates to OOM errors.
Solution
To fix the issue, take the following steps:
Update
argocd configmapto ignoreservice-monitorsby updatingresource.exclusions.-
Create a backup of the old
configmap:kubectl get configmap argocd-cm -n argocd -o yaml >> argocd-cm-old.yamlkubectl get configmap argocd-cm -n argocd -o yaml >> argocd-cm-old.yaml -
Edit
argocd-cm:kubectl edit configmap argocd-cm -n argocdkubectl edit configmap argocd-cm -n argocd -
Add a new data entry for
resource.exclusions:data: resource.exclusions: | - apiGroups: - monitoring.coreos.com kinds: - ServiceMonitor clusters: - "*"data: resource.exclusions: | - apiGroups: - monitoring.coreos.com kinds: - ServiceMonitor clusters: - "*"
Delete the
envoy-stats-monitorservice monitor under theistio-systemnamespace:kubectl -n istio-system delete servicemonitor envoy-stats-monitorkubectl -n istio-system delete servicemonitor envoy-stats-monitor -
Force-delete the Prometheus pods:
kubectl delete pod prometheus-rancher-monitoring-prometheus-0 -n cattle-monitoring-system kubectl delete pod prometheus-rancher-monitoring-prometheus-1 -n cattle-monitoring-systemkubectl delete pod prometheus-rancher-monitoring-prometheus-0 -n cattle-monitoring-system kubectl delete pod prometheus-rancher-monitoring-prometheus-1 -n cattle-monitoring-system -
Wait for the Prometheus pods under
cattle-monitoring-systemto restart successfully.
Deleting the the wal and chunks_head directories results in a loss of all monitoring data gathered during the days these files were accumulated. However, once Prometheus is up and running again, any new alerts and metrics data will be accessible.
