- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Sample Azure infrastructure setup
The following table lists the steps you need to take to configure the infrastructure in Azure for both single-node evaluation and multi-node HA-ready production profiles.
| Step | Instructions | Single-node evaluation profile | Multi-node HA-ready production profile | Required during installation |
Step 1: Configure a VM node |
<details>: Basics; Configure Disks; Networking Configure the DNS of the VM; Partitioning the disk; Additional networking configuration for multi-node |
Configure one node |
Configure a minimum of 3 nodes.
N/A |
Required |
Required |
Required |
You must create an Azure storage account if you opt for external objectstore. | ||||
For production deployments: For test or evaluation deployments: |
Required |
Required |
Step 6: Install Automation Suite |
At this point, configuration is complete, and you can install Automation Suite. |
