Step 2: Updating AD integration and authentication
To configure AD integration, refer to Configuring SSO: Active Directory.
If AD integration and authentication were enabled in the standalone deployment, take the following steps in the Automation Suite cluster:
  • Make sure the domain controllers are discoverable by the Automation Suite cluster. If not, use the Kube DNS configuration;
  • Configure integrated Windows authentication and Kerberos authentication using keytab file;
  • Configure LDAP integration via the Portal under the host admin;
  • Configure Windows authentication via the Portal under the host admin;
  • Configure LDAPS for secure connection to LDAP.
    Note:
    The account used for the LDAP integration configuration should only have read access to all trusted domains in the current and trusted forests.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
