- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Configuring the DNS
The Automation Suite cluster is exposing multiple URLs to access the cluster management tools and the suite core functionality, all based on a common FQDN.
You need to configure the DNS for the common FQDN and the subdomains specific to each tool as shown in the following table.
Application |
Domain |
Example URL |
Automation Suite |
Application Lifecycle Management (ALM) |
Monitoring / Observability |
Object Store |
Docker Registry |
Insights |
A Record
in Advanced DNS or Management section of your domain as shown in the following table:
Type |
Host |
Value |
A Record (or CName )
automationsuite (or a subdomain to access Automation Suite)
*.automationsuite (or a subdomain to access Automation Suite)
See the following example for the configuration:
wildcard is too generic, add a separate record or rule for the following subdomains: alm
, monitoring
, objectstore
, registry
, and insights
As a workaround, you can use a private domain for testing purposes only.
For an example, see Sample Azure infrastructure setup.
