- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
When trying to upgrade to a new Automation Suite version, you might see the following error message: Ceph objectstore is not completely healthy at the moment. Inner exception - Timeout waiting for all PGs to become active+clean.
Solution
To fix this upgrade issue, verify if the OSD pods are running and healthy by running the following command:
kubectl -n rook-ceph get pod -l app=rook-ceph-osd --no-headers | grep -P '([0-9])/\1' -v
If the command does not output any pods, verify if Ceph placement groups (PGs) are recovering or not by running the following command:
function is_ceph_pg_active_clean() { local return_code=1 if kubectl -n rook-ceph exec deploy/rook-ceph-tools -- ceph status --format json | jq '. as $root | ($root | .pgmap.num_pgs) as $total_pgs | try ( ($root | .pgmap.pgs_by_state[] | select(.state_name == "active+clean").count) // 0) as $active_pgs | if $total_pgs == $active_pgs then true else false end' | grep -q 'true';then return_code=0 fi [[ $return_code -eq 0 ]] && echo "All Ceph Placement groups(PG) are active+clean" if [[ $return_code -ne 0 ]]; then echo "All Ceph Placement groups(PG) are not active+clean. Please wait for PGs to become active+clean" kubectl -n rook-ceph exec deploy/rook-ceph-tools -- ceph pg dump --format json | jq -r '.pg_map.pg_stats[] | select(.state!="active+clean") | [.pgid, .state] | @tsv' fi return "${return_code}" } # Execute the function multiple times to get updated ceph PG status is_ceph_pg_active_cleanfunction is_ceph_pg_active_clean() { local return_code=1 if kubectl -n rook-ceph exec deploy/rook-ceph-tools -- ceph status --format json | jq '. as $root | ($root | .pgmap.num_pgs) as $total_pgs | try ( ($root | .pgmap.pgs_by_state[] | select(.state_name == "active+clean").count) // 0) as $active_pgs | if $total_pgs == $active_pgs then true else false end' | grep -q 'true';then return_code=0 fi [[ $return_code -eq 0 ]] && echo "All Ceph Placement groups(PG) are active+clean" if [[ $return_code -ne 0 ]]; then echo "All Ceph Placement groups(PG) are not active+clean. Please wait for PGs to become active+clean" kubectl -n rook-ceph exec deploy/rook-ceph-tools -- ceph pg dump --format json | jq -r '.pg_map.pg_stats[] | select(.state!="active+clean") | [.pgid, .state] | @tsv' fi return "${return_code}" } # Execute the function multiple times to get updated ceph PG status is_ceph_pg_active_cleanNote:If none of the affected Ceph PG recovers even after waiting for more than 30 minutes, raise a ticket with UiPath® Support.
If the command outputs pod(s), you must first fix the issue affecting them:
If a pod is stuck in
Init:0/4, then it could be a PV provider (Longhorn) issue. To debut this issue, raise a ticket with UiPath® Support. -
If a pod is in
CrashLoopBackOff, fix the issue by running the following command:function cleanup_crashing_osd() { local restart_operator="false" local min_required_healthy_osd=1 local in_osd local up_osd local healthy_osd_pod_count local crashed_osd_deploy local crashed_pvc_name if ! kubectl -n rook-ceph exec deploy/rook-ceph-tools -- ceph osd pool ls detail | grep 'rook-ceph.rgw.buckets.data' | grep -q 'replicated'; then min_required_healthy_osd=2 fi in_osd=$(kubectl -n rook-ceph exec deploy/rook-ceph-tools -- ceph status -f json | jq -r '.osdmap.num_in_osds') up_osd=$(kubectl -n rook-ceph exec deploy/rook-ceph-tools -- ceph status -f json | jq -r '.osdmap.num_up_osds') healthy_osd_pod_count=$(kubectl -n rook-ceph get pod -l app=rook-ceph-osd | grep 'Running' | grep -c -P '([0-9])/\1') if ! [[ $in_osd -ge $min_required_healthy_osd && $up_osd -ge $min_required_healthy_osd && $healthy_osd_pod_count -ge $min_required_healthy_osd ]]; then return fi for crashed_osd_deploy in $(kubectl -n rook-ceph get pod -l app=rook-ceph-osd | grep 'CrashLoopBackOff' | cut -d'-' -f'1-4') ; do if kubectl -n rook-ceph logs "deployment/${crashed_osd_deploy}" | grep -q '/crash/'; then echo "Found crashing OSD deployment: '${crashed_osd_deploy}'" crashed_pvc_name=$(kubectl -n rook-ceph get deployment "${crashed_osd_deploy}" -o json | jq -r '.metadata.labels["ceph.rook.io/pvc"]') info "Removing crashing OSD deployment: '${crashed_osd_deploy}' and PVC: '${crashed_pvc_name}'" timeout 60 kubectl -n rook-ceph delete deployment "${crashed_osd_deploy}" || kubectl -n rook-ceph delete deployment "${crashed_osd_deploy}" --force --grace-period=0 timeout 100 kubectl -n rook-ceph delete pvc "${crashed_pvc_name}" || kubectl -n rook-ceph delete pvc "${crashed_pvc_name}" --force --grace-period=0 restart_operator="true" fi done if [[ $restart_operator == "true" ]]; then kubectl -n rook-ceph rollout restart deployment/rook-ceph-operator fi return 0 } # Execute the cleanup function cleanup_crashing_osdfunction cleanup_crashing_osd() { local restart_operator="false" local min_required_healthy_osd=1 local in_osd local up_osd local healthy_osd_pod_count local crashed_osd_deploy local crashed_pvc_name if ! kubectl -n rook-ceph exec deploy/rook-ceph-tools -- ceph osd pool ls detail | grep 'rook-ceph.rgw.buckets.data' | grep -q 'replicated'; then min_required_healthy_osd=2 fi in_osd=$(kubectl -n rook-ceph exec deploy/rook-ceph-tools -- ceph status -f json | jq -r '.osdmap.num_in_osds') up_osd=$(kubectl -n rook-ceph exec deploy/rook-ceph-tools -- ceph status -f json | jq -r '.osdmap.num_up_osds') healthy_osd_pod_count=$(kubectl -n rook-ceph get pod -l app=rook-ceph-osd | grep 'Running' | grep -c -P '([0-9])/\1') if ! [[ $in_osd -ge $min_required_healthy_osd && $up_osd -ge $min_required_healthy_osd && $healthy_osd_pod_count -ge $min_required_healthy_osd ]]; then return fi for crashed_osd_deploy in $(kubectl -n rook-ceph get pod -l app=rook-ceph-osd | grep 'CrashLoopBackOff' | cut -d'-' -f'1-4') ; do if kubectl -n rook-ceph logs "deployment/${crashed_osd_deploy}" | grep -q '/crash/'; then echo "Found crashing OSD deployment: '${crashed_osd_deploy}'" crashed_pvc_name=$(kubectl -n rook-ceph get deployment "${crashed_osd_deploy}" -o json | jq -r '.metadata.labels["ceph.rook.io/pvc"]') info "Removing crashing OSD deployment: '${crashed_osd_deploy}' and PVC: '${crashed_pvc_name}'" timeout 60 kubectl -n rook-ceph delete deployment "${crashed_osd_deploy}" || kubectl -n rook-ceph delete deployment "${crashed_osd_deploy}" --force --grace-period=0 timeout 100 kubectl -n rook-ceph delete pvc "${crashed_pvc_name}" || kubectl -n rook-ceph delete pvc "${crashed_pvc_name}" --force --grace-period=0 restart_operator="true" fi done if [[ $restart_operator == "true" ]]; then kubectl -n rook-ceph rollout restart deployment/rook-ceph-operator fi return 0 } # Execute the cleanup function cleanup_crashing_osd
After fixing the crashing OSD, verify if PGs are recovering or not by running the following command:
