- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
You can enable and disable products in Automation Suite at any point post-installation.
cluster_config.json file stored in the
/opt/UiPathAutomationSuite folder, and rerun the service
installer step.
Enabling or disabling Action Center
cluster_config.json file:
"actioncenter": {
"enabled": "true" //Set to "false" to disable the Action Center
}"actioncenter": {
}Enabling or Disabling Apps
"apps": {
"enabled": "true" //Set to "false" to disable the Apps
}"apps": {
}Enabling or disabling AI Center
enable flag and an SQL database.
sql_connection_string_template_jdbc in
cluster_config.json, then the default AI Center
database name is AutomationSuite_AICenter.
sql_connection_str inside the AI Center field. This overrides the default database and connection string template set in sql_connection_string_template_jdbc.
If AI Center does not require an external Orchestrator, see the following configuration details for enabling or disabling AI Center in
:cluster_config.json"aicenter": { "enabled": "true", //Set to "false" to disable the AICenter "sql_connection_str": "" //Optional and only required to override the default database name }"aicenter": { "enabled": "true", //Set to "false" to disable the AICenter "sql_connection_str": "" //Optional and only required to override the default database name } -
If AI Center requires an external Orchestrator, see the following configuration details for enabling or disabling AI Center in
cluster_config.json:"aicenter": { "enabled": "true", //Set to "false" to disable the AI Center "sql_connection_str": "" //Optional and only required to override the default database name "orchestrator_url": "https://orchestrator.example.com", //Specify the Orchestrator URL for AI Center "identity_server_url": "https://orchestrator.example.com/identity", //Specify the Identiy URL for AI Center "orchestrator_cert_file_path": "/opt/UiPathAutomationSuite/UiPath_Installer/orch.cer", //Specify the path to the Orchestrator certificate "identity_cert_file_path": "/opt/UiPathAutomationSuite/UiPath_Installer/orch.cer", //Specify the path to Identity certificate file "metering_api_key": "test" //Specify the metering API key }"aicenter": { "enabled": "true", //Set to "false" to disable the AI Center "sql_connection_str": "" //Optional and only required to override the default database name "orchestrator_url": "https://orchestrator.example.com", //Specify the Orchestrator URL for AI Center "identity_server_url": "https://orchestrator.example.com/identity", //Specify the Identiy URL for AI Center "orchestrator_cert_file_path": "/opt/UiPathAutomationSuite/UiPath_Installer/orch.cer", //Specify the path to the Orchestrator certificate "identity_cert_file_path": "/opt/UiPathAutomationSuite/UiPath_Installer/orch.cer", //Specify the path to Identity certificate file "metering_api_key": "test" //Specify the metering API key }Note:metering_api_keyis the Document Understanding or AI Units API key from the AI Center cloud account.
To complete the installation, run the following post-installation command:
./configureUiPathAS.sh aicenter configure --installation-token <identity token>./configureUiPathAS.sh aicenter configure --installation-token <identity token>Enabling or disabling Automation Hub
automation_hub section of the cluster_config.json file, set the enabled flag
to true:
"automation_hub": {
"enabled": "true" //Set to "false" to disable Automation Hub
"sql_connection_str": "" //Optional and only require to override the default database name
}"automation_hub": {
}enabled flag to false in the
automation_hub section of the cluster_config.json file.
Enabling or disabling Automation Ops
sql_connection_string_template in cluster_config.json, then the default database name for
Automation Ops is AutomationSuite_Platform.
sql_connection_str inside the Automation Ops field. This overrides the default database and connection string template set in sql_connection_string_template.
"automation_ops": {
"enabled": "true", //Set to "false" to disable the Automation Ops
}"automation_ops": {
}Enabling or disabling Automation Suite Robots
To enable Automation Suite Robots, take the following steps:
Enable the
asrobotsflag in thefile. If you want to enable package caching, make sure to properly configure thecluster_config.jsonpackagecachingandpackagecachefolderflags as well.{ "asrobots": { "enabled": Boolean, "packagecaching": Boolean, "packagecachefolder": String } }{ "asrobots": { "enabled": Boolean, "packagecaching": Boolean, "packagecachefolder": String } }Parameter
Default value
packagecachingtrueWhen set totrue, robots use a local cache for package resolution.packagecachefolder/uipath_asrobots_package_cacheThe disk location on the serverless agent node where the packages are stored.
Note: Package caching optimizes your process runs and allows them to run faster. NuGet packages are fetched from the filesystem instead of being downloaded from the Internet/network. This requires an additional space of minimum 10GB and should be allocated to a folder on the host machine filesystem of the dedicated nodes. -
If you use a multi-node HA-ready production setup, you must configure a specialized agent node for Automation Suite Robots. In single-node evaluation mode, an additional node is optional. For instructions, see Adding a dedicated agent node for Automation Suite Robots.
asrobots flag in the cluster_config.json file.
Enabling or disabling Data Service
sql_connection_string_template in cluster_config.json, then the default database name is
AutomationSuite_DataService.
sql_connection_str inside the Data Service field. This overrides the default database and connection string template set in sql_connection_string_template.
"dataservice": {
"enabled": "true", //Set to "false" to disable the Data Service,
}"dataservice": {
}Enabling or disabling Document Understanding
sql_connection_string_template_odbc in
is AutomationSuite_DU_Datamanager.
sql_connection_str inside the Document Understanding field. This overrides the default database and connection string template set in sql_connection_string_template_odbc.
If you perform an offline installation, you need to download the offline bundle for Document Understanding as well. Before enabling Document Understanding, please refer to Install and Use Document Understanding.
"documentunderstanding": {
"enabled": true,
"sql_connection_str": "***" // dotnet connection string,
"datamanager": {
"sql_connection_str": "***" // odbc connection string
"pyodbc_sql_connection_str": "***" // python sql connection string
}"documentunderstanding": {
"enabled": true,
"datamanager": {
}Enabling or Disabling Insights
sql_connection_string_template in cluster_config.json, then the default database name is AutomationSuite_Insights.
sql_connection_str inside the Insights field. This overrides the default database and connection string template set in sql_connection_string_template.
Insights has an optional SMTP configuration to enable receiving email notifications. Refer to Advanced installation experience for more details.
"insights": {
"enabled": "true", //Set to "false" to disable the Insights,
}"insights": {
}Enabling or disabling Orchestrator
orchestrator flag to true in
"orchestrator": {
"enabled": "true" //Set to "false" to disable Orchestrator
}"orchestrator": {
}orchestrator flag to false in
Enabling or disabling Process Mining
- Enable the
processminingflag. -
Configure the following connection string templates:
sql_connection_string_templatesql_connection_string_template_jdbcsql_connection_string_template_odbcsql_connection_string_template_sqlalchemy_pyodbc
In multi-node HA-ready production installations, add a separate connection string for the second SQL Server. Note that in single-node evaluation installations, the seconds SQL Server is recommended. For instructions on how to configure the seconds SQL Server, see SQL requirements for Process Mining
"processmining": { "enabled": true, "sql_connection_str": "", // dotnet connection string "sqlalchemy_pyodbc_sql_connection_str": "", "warehouse": { "sql_connection_str": "", "sqlalchemy_pyodbc_sql_connection_str": "" } }"processmining": { "enabled": true, "sql_connection_str": "", // dotnet connection string "sqlalchemy_pyodbc_sql_connection_str": "", "warehouse": { "sql_connection_str": "", "sqlalchemy_pyodbc_sql_connection_str": "" } }
processmining flag.
Enabling or disabling Task Mining
enable flag and an SQL Database.
AutomationSuite_Task_Mining.
To change the name to something other than the default, you can update the sql_connection_str inside the Task Mining field to override the default database and connection string template set in sql_connection_string_template
Task Mining requires a few additional steps, including the provisioning of a dedicated agent node for AI-specific workloads.
Before enabling Task Mining, please refer Task Mining installation section Adding a dedicated agent node for Task Mining.
"task_mining": {
"enabled": "true", //Set to "false" to disable the Task Mining,
}"task_mining": {
}Un-tainting for workloads
If desired, the Task Mining node can be repurposed as an agent node. To accomplish this, run the following commands:
- Check an actual taint using
kubectl describe node task-mining_nodenamecommand. - Run the command
kubectl taint nodes task-mining_nodename task.mining/cpu=present:NoSchedule-. - Check taint has disappeared using
Enabling or disabling Test Manager
AutomationSuite_Test_Manager.
sql_connection_str inside the Test Manager field. This overrides the default database and connection string template set in sql_connection_string_template.
"test_manager": {
"enabled": "true", //Set to "false" to disable the Test Manager,
}"test_manager": {
}cluster_config.json, run the following command on the installer to update the service configuration.
For online installations:
./install-uipath.sh -i cluster_config.json -o output.json -f -s --accept-license-agreement./install-uipath.sh -i cluster_config.json -o output.json -f -s --accept-license-agreement -
For offline installations:
./install-uipath.sh -i cluster_config.json -o output.json -f -s --install-type offline --accept-license-agreement./install-uipath.sh -i cluster_config.json -o output.json -f -s --install-type offline --accept-license-agreement
- Step 1: Changing the product selection in the configuration file
- Enabling or disabling Action Center
- Enabling or Disabling Apps
- Enabling or disabling AI Center
- Enabling or disabling Automation Hub
- Enabling or disabling Automation Ops
- Enabling or disabling Automation Suite Robots
- Enabling or disabling Data Service
- Enabling or disabling Document Understanding
- Enabling or Disabling Insights
- Enabling or disabling Orchestrator
- Enabling or disabling Process Mining
- Enabling or disabling Task Mining
- Enabling or disabling Test Manager
- Step 2: Running the installer to update the new product configuration
