- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Managing products
- Configuring the FQDN post-installation
- Setting up Kerberos authentication
- Setting up Elasticsearch and Kibana
- Forwarding application logs to Splunk
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
cluster_config.json
file for all the nodes in the cluster.
fqdn
- update this field with new FQDN that you need to access the cluster.Important:Thefqdn
field only supports lowercase letters.
fixed_rke_address
- if this value is identical to thefqdn
field incluster_config.json
, then you need to update this value as well to reflect the new FQDN.Note:Changing the FQDN also requires new server certificates. If a new certificate is available, you have two options: either continue with the new self-signed certificate configured by the installer automatically, or stop the installation and bring in a new certificate.
You can configure the certificate via theserver_certificate
To update the FQDN in single-node evaluation mode, take the following steps:
- Navigate to the
UiPathAutomationSuite
folder (the location of the installer bundle). - Run the following command to update the FQDN:
Online
sudo ./install-uipath.sh -i ./cluster_config.json -o output.json -a --accept-license-agreement
Offline
Run the following command to update the FQDN for the infrastructure:
sudo ./install-uipath.sh -i ./cluster_config.json -o ./output.json -k --offline-bundle ./sf-infra.tar.gz --offline-tmp-folder /uipath/tmp --accept-license-agreement
Run the following command to update the FQDN for the fabric and services:
sudo ./install-uipath.sh -i ./cluster_config.json -o ./output.json -f -s --install-type offline --accept-license-agreement
To update the FQDN in multi-node HA-ready production mode, take the following steps:
There are some variations between the commands you run on the first server node, those you execute on the subsequent server nodes, and those you use on agent nodes, as follows:
- The
-a
option is exclusively for commands executed on the first server node. This is where you must run the fabric and service installer. - The
-k
option specifically applies to commands run on the following server nodes, and it skips the execution of the fabric and service installer. - The
-j server
option is used to distinguish between server nodes and agent nodes.
