Antivirus causes installation issues
Description​
Using an antivirus results in an Automation Suite installation issue.
Solution​
If your antivirus application leads to issues, it's recommended to raise a support ticket with the antivirus provider. While you have an option to include the following folders in the antivirus allowlist, a more appropriate solution is get help from your antivirus provider's support team:
  • /var/lib/rancher
  • /var/lib/kubelet
  • /opt/UiPathAutomationSuite
  • /datadisk
  • /var/lib/rancher/rke2/server/db
  • /var/lib/longhorn
  • Description​
  • Solution​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
