Secret not found in UiPath namespace
If service installation fails in a cluster using ceph as incluster object store, and checking kubectl -n uipath get pods returns failed pods, take the following steps.
Solution
  1. Check kubectl -n uipath describe pod <pod-name> and look for secret not found.
  2. If the secret is not found, then look for credential manager job logs and see if it failed.
    # get the credential manager pod name
    kubectl -n istio-system get pods | grep credential-manager
    # check the credential manager pod logs
    kubectl -n istio-system logs <credential-manager-pod-name># get the credential manager pod name
  3. If the credential manager job failed and kubectl get pods -n rook-ceph|grep rook-ceph-tool returns more than one pod, do the following:
    1. delete rook-ceph-tool that is not running.
    2. go to ArgoCD UI and sync sfcore appllication to retrigger the credential manager job.
    3. Once the credential manager job completes, check if all secrets are created by looking at the credential-manager job logs.
    4. Now sync the application corresponding to the failed pod.
  • Description
  • Solution
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
