- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Migrating standalone Orchestrator to Automation Suite
When migrating standalone Orchestrator to Automation Suite, a series of additional steps might be required, depending on the way you configured standalone Orchestrator.
Before starting the migration operation, you may need to prepare your settings. For details, see Preparing Orchestrator.
After completing the migration operation, you may need to adjust some of your settings. For details, see Updating the Orchestrator configuration.
