Automation Suite
- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Automation Suite Installation Guide
Last updated Apr 24, 2024
Pods in RabbitMQ or cattle-monitoring-system or other StatefulSet pods are stuck in the init state.
Occasionally, upon node power failure or during upgrade, an issue causes the pods in RabbitMQ or cattle-monitoring-system to get stuck in init state as the volume required for attaching the PVC to a pod is missing.
Verify if the problem is indeed related to the StatefulSet volume attachment by running the following command:
kubectl -n <namespace> describe pod <pod-name> | grep "cannot get resource \"volumeattachments\" in API group \" storage.k8s.io\""
If it is related to the StatefulSet volume attachment, it will show an error message.
