- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
/opt/UiPathAutomationSuite folder on all the nodes. If you do not have enough space, you can either increase the capacity of this folder or remove all
the previous installer files except for cluster_config.json. You can always download the previous installer again.
df -h /opt/UiPathAutomationSuite.
To prepare for the upgrade, take the following steps:
Hydrating Docker-registry and Containerd
docker-registry and containerd with container images for the new version of products before the upgrade by taking the following steps.
Make sure not to hydrate containerd and/or other infra images more that 10 hours before the upgrade.
If you upgrade Document Understanding and Computer Vision, you must download the base images that match your upgraded Automation Suite version (use the base image that corresponds with your ML Package version) and hydrate them to your docker registry prior to upgrade to avoid disruption to your running DU skills. To download the Document Understanding and Computer Vision installation packages, see Downloading the installation packages.
Configuring the backup
To configure the backup, take the following steps:
Once the backup is created, continue with the following steps.
Putting the cluster in maintenance mode
Putting the cluster in maintenance mode will shut down the ingress controller and all the UiPath services, blocking all the incoming traffic to the Automation Suite cluster.
Updating Kubernetes and Other Infrastructure Components
You must perform the infrastructure upgrade on all the nodes in the cluster.
You cannot perform this step on multiple nodes at the same time; you must wait for the upgrade to finish on each node before moving to another.
Updating Shared Components and UiPath Product Services
This step upgrades the fabric and service components running with the cluster. You must follow this steps only on the primary server node.
After performing the upgrade, you can take the following additional steps:
To verify if Automation Suite is healthy, run:
kubectl get applications -n argocdkubectl get applications -n argocd -
If you experience issues with image vulnerabilities or storage consumption after performing an upgrade, delete the images from the old installer. For details, see the Troubleshooting section.
After upgrading to Automation Suite 2022.10.13 or newer, you can clean up the previous version images after the upgrade from the in-cluster Docker registry. For instructions, see How to delete images from the old installer after upgrade.
Enabling the backup post-upgrade
Make sure Automation Suite is up and running and your automation continues as expected before proceeding with the next steps.
Before starting to upgrade the cluster, the upgrade script automatically creates a backup of the cluster and then temporarily disables it. You may want to enable the backup manually once the upgrade is done.
To enable the backup, follow the instructions in described in the Backing up and restoring the cluster documentation.
