- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
An Azure known issue incorrectly shows the rotational flag enabled for the Azure SSD disk. As a result, the Azure disk is not marked as SSD, and the following error occurs when trying to configure the Objectstore disk:
ERROR][2022-08-18T05:26:35+0000]: Rotational device: '/dev/sdf' is not recommended for ceph OSD
Solution
To fix this issue and mark the Azure SSD disk as non-rotational, run the following commands:
echo "0" > "/sys/block/{raw_device_name}/queue/rotational"
echo "KERNEL==\"${raw_device_name}\", ATTR{queue/rotational}=\"0\"" >> "/etc/udev/rules.d/99-ceph-raw-osd-mark-ssd.rules"
udevadm control --reload
udevadm trigger
udevadm trigger
Example:
echo "0" > "/sys/block/sdf/queue/rotational"
echo "KERNEL==\"sdf\", ATTR{queue/rotational}=\"0\"" >> "/etc/udev/rules.d/99-ceph-raw-osd-mark-ssd.rules"
udevadm trigger
udevadm trigger
