- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Entry points
- Main stack – principal entry point:
- Network stack
- Uipath-sf stack
- Uipath-sf stack
Nested stacks
Uipath-sf:
- SSL stack
- Routing stack
- Server stack
- Database stack
- Backup stack
- Management stack
- Lambda functions (
AWS::Lambda::Function):FindAMIFunction– for finding a matching AMI Id.CreateInputJsonFunction– for creating the configuration used by the Automation Suite installer.ComputeResourceSizeFunction– for computing the minimum EC2 instances hardware configuration needed, based on the selected services and deployment type.
- IAM roles (
AWS::IAM::Role) for the Lambda functions to provide minimum permissions:FindAmiLambdaRoleCreateInputJsonLambdaRoleComputeResourceSizeLambdaRole
- Secrets (
AWS::SecretsManager::Secret) to store sensitive information:RDSPasswordOrgSecretPlatformSecretArgoCdSecretArgoCdUserSecretInputJsonSecretKubeconfigSecret
- SSL Stack (optional)
- Network stack (optional)
Backup stack (optional):
ClusterBackupStorage(AWS::EFS::FileSystem) – Amazon Elastic File System used to store the backup.SharedStorageSecurityGroup(AWS::EC2::SecurityGroup) – Security group used to allow NFS network connections from the cluster nodes.SharedStorageMountTargetOne(AWS::EFS::MountTarget) – Resource that creates the mount target for the EFS file system and the first private subnet.SharedStorageMountTargetTwo(AWS::EFS::MountTarget) – Resource that creates the mount target for the EFS file system and the second private subnet.SharedStorageMountTargetThree(AWS::EFS::MountTarget) – Optional resource that creates the mount target for the EFS file system and the third private subnet.
- Database stack:
RDSDBInstance(AWS::RDS::DBInstance) – The Amazon RDS DB instance. The DB SKU isdb.m5.2xlarge.DBSubnetGroup(AWS::RDS::DBSubnetGroup) – Private subnet group that contains the private subnets.DbSecurityGroup(AWS::EC2::SecurityGroup) – Security Group allowing access to the DB instance.PMRDSDBInstance(AWS::RDS::DBInstance) – Dedicated Amazon RDS DB instance for Process Mining. Only deployed when Process Mining is enabled and the deployment isMulti Node. The DB SKU isdb.m5.4xlarge.
- Routing stack:NOTE: The Alb and Nlb stacks are mutually exclusive configurations
- Alb stack:
ExternalLoadBalancer(AWS::ElasticLoadBalancingV2::LoadBalancer) – Application load balancer used to distribute Automation Suite traffic. It can be internal or internet-facing.ELBSecurityGroup(AWS::EC2::SecurityGroup) – The security group applied to the load balancer.HttpsTargetGroup(AWS::ElasticLoadBalancingV2::TargetGroup) – The target group of the load balancer.HttpsListener(AWS::ElasticLoadBalancingV2::Listener) – The listener for the load balancer.
- Nlb stack:
ExternalLoadBalancer(AWS::ElasticLoadBalancingV2::LoadBalancer) – Network load balancer used to distribute Automation Suite traffic. It can be internal or internet-facing.TcpTargetGroup(AWS::ElasticLoadBalancingV2::TargetGroup) – The target group of the load balancer.TcpListener(AWS::ElasticLoadBalancingV2::Listener) – The listener for the load balancer.
KubeLoadBalancer(AWS::ElasticLoadBalancingV2::LoadBalancer) – Private network load balancer used for node registration.KubeApiTcpTargetGroup(AWS::ElasticLoadBalancingV2::TargetGroup) – The target group for the node registration traffic of theKubeLoadBalancer.KubeApiTcpListener(AWS::ElasticLoadBalancingV2::Listener) – The listener for the node registration traffic of theKubeLoadBalancer.Rke2RegistrationTcpTargetGroup(AWS::ElasticLoadBalancingV2::TargetGroup) – The target group for the node registration traffic of theKubeLoadBalancer.Rke2RegistrationTcpListener(AWS::ElasticLoadBalancingV2::Listener) – The listener for the node registration traffic of theKubeLoadBalancer.RootRecordSet(AWS::Route53::RecordSet) – DNS A record for the FQDN.SubdomainRecordSet(AWS::Route53::RecordSet) – DNS A record for the subdomains of the FQDN.
- Alb stack:
- Management stack:
LifecycleAutomationLogs(AWS::Logs::LogGroup) – Log group for logging events from the SSM automation.ClusterOperationsAutomationLogs– Log group for logging events related to cluster operations.OnDemandRestoreStateMachine(AWS::StepFunctions::StateMachine) – Step function used to orchestrate the restore flow.- SSM Documents (
AWS::SSM::Document) sets of steps used to provide graceful node removal:ServerRemoveInstanceDocumentAgentRemoveInstanceDocumentUpdateAMIDocument– Updates the AMI ID for the Auto Scaling Groups.RegisterAiCenter– Registers AI Center to an external Orchestrator provided at deployment time.OnDemandBackup– Creates a manual snapshot of the Automation Suite cluster.GetBackupList– Retrieves all available snapshots for the Automation Suite cluster.OnDemandRestoreDocument– Restores the Automation Suite cluster from a given snapshot.
- Autoscaling Lyfecycle hooks (
AWS::AutoScaling::LifecycleHook) that allow us to run the SSM documents when an EC2 instance receives an instance termination event:ServerAsgLifeCycleHookTerminatingAgentAsgLifeCycleHookTerminatingAsRobotsAsgLifeCycleHookTerminating
- Event rules (
AWS::Events::Rule) that trigger the execution of the SSM Documents:ServerTerminateEventRuleAgentTerminateEventRuleAsRobotsTerminateEventRule
- IAM roles (
AWS::IAM::Role) needed for running SSM Documents and adding logs to the Log Group:AutomationAssumeRoleEventsBridgeAssumeRoleStateMachinesAssumeRole
Note:AutomationAssumeRoleandStateMachinesAssumeRoleallow full access to Amazon SSN. For more information, see AmazonSSMFullAccess. - Server stack:
ServerLaunchConfiguration(AWS::EC2::LaunchTemplate) – EC2 instance configuration for the server nodes. Disk configuration:- OS disk – sku gp3, capacity 256GB
- Cluster disk – sku gp3, capacity 300GB
- etcd disk – sku io1, capacity 32GB
- Data disk – sku gp3, capacity 512GB regardless of the selected services.
- Objectstore disk – sku gp3, capacity 512GB
- Optional disk for Automation Suite Robots package caching – sku gp3, capacity 32GB. The disk is deployed only if the the Automation Suite Robots service is enabled in a single-node deployment
AgentLaunchConfiguration(AWS::EC2::LaunchTemplate) – EC2 instance configuration for the agent nodes. Disk configuration:- OS disk – sku gp3, capacity 128GB
- Cluster disk – sku gp3, capacity 256GB
ASRobotsLaunchTemplate(AWS::EC2::LaunchTemplate) – EC2 instance configuration for the ASRobots nodes. Disk configuration:- OS disk – sku gp3, capacity 128GB
- Robot package caching disk - sku gp3, capacity 32GB
GpuEnabledNode(AWS::EC2::Instance) – Optional GPU node. It has the same disk configuration as an agent.TaskMiningNode(AWS::EC2::Instance) - Optional Task Mining node. Deployed only if the Task Mining service is selected. It has the same disk configuration as an agent.BastionHost(AWS::EC2::Instance) – Optional EC2 instance used to SSH to cluster nodes. It has thet3.largeinstance type and a 200GB gp3 disk.ServerAutoScalingGroup(AWS::AutoScaling::AutoScalingGroup) – Auto scaling group for the servers.AgentAutoScalingGroup(AWS::AutoScaling::AutoScalingGroup) – Auto scaling group for the agents.ASRobotsAutoScalingGroup– Auto scaling Group for dedicated Automation Suite Robots nodes. The capacity of this scaling group is 1 if the deployment isMulti Nodeand the Automation Suite Robots service is enabled, and 0 otherwise.- Optional
ServiceFabricIamRole(AWS::IAM::Role) that has permissions to:- write logs
- read EC2 instances configurations
- download AWS Quickstart resources
- access the Automation Suite installation configuration secret
- access the cluster kubeconfig configuration secret
ServiceFabricSecurityGroup(AWS::EC2::SecurityGroup) – Security Group allowing access to UiPath® applications.BastionSecurityGroup(AWS::EC2::SecurityGroup) – Optional Security Group allowing SSH access to BastionAsgProcessModifierFunction(AWS::Lambda::Function) – Used to modify the ASG processes during CF stack creation.AsgProcessModificationRole(AWS::IAM::Role) – IAM role to provide minimum permissions for theAsgProcessModifierFunction- SSM parameters (
AWS::SSM::Parameter):InstanceAMIIdSSMParameter– Stores the AMI ID of the nodes.InstanceAMIImageNameSSMParameter– Holds the Image Name used at deployment time or updated via theUpdateAMIDocument.
AWS::AutoScaling::LifecycleHook) that allow us to transition EC2 instances to InService state after the installer succeeded:ServerAsgLifeCycleHookLaunchingAgentAsgLifeCycleHookLaunchingASRobotsAsgLifeCycleHookLaunching
The template dynamically computes the hardware needed for the deployment as follows:
- Depending on the services installed, it sets minimum requirements at cluster level.
- Depending on the deployment profile (multi-node or single-node profile), it sets minimum requirements for a single VM.
- Selects the instance types based on their availability in the region you deploy and the aforementioned requirements.
The following table shows the mappings between deployment and possible instance types:
Deployment type |
Instance types |
Single-node, services selection that needs less than 16 CPUs |
c5.4xlarge, c5a.4xlarge, m5.4xlarge, m5a.4xlarge |
Single-node, services selection that needs more than 16 CPUs |
c5a.8xlarge, c5.9xlarge, m5.8xlarge |
Multi-node, services selection that needs less than 48 CPUs |
c5.4xlarge, c5a.4xlarge, m5.4xlarge, m4.4xlarge |
Multi-node, services selection that needs more than 48 CPUs |
c5a.8xlarge, c5.9xlarge, m5.8xlarge, m5a.8xlarge |
