- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- RKE2 not getting started due to space issue
- SQL validation fails during upgrade
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Last updated Nov 6, 2025
During the automated upgrade from Automation Suite 2021.10, the CNI provider is migrated from Canal to Cilium. This operation requires that all nodes are restarted. On rare occasions, one or more nodes might not be successfully rebooted, causing pods running on those nodes to remain unhealthy.
Identify failed restarts.
During the Ansible execution, you might see output similar to the following snippet:
TASK [Reboot the servers] *************************************************************************************************************************** fatal: [10.0.1.6]: FAILED! => msg: 'Failed to connect to the host via ssh: ssh: connect to host 10.0.1.6 port 22: Connection timed out'TASK [Reboot the servers] *************************************************************************************************************************** fatal: [10.0.1.6]: FAILED! => msg: 'Failed to connect to the host via ssh: ssh: connect to host 10.0.1.6 port 22: Connection timed out'Alternatively, browse the logs on the Ansible host machine, located at/var/tmp/uipathctl_<version>/_install-uipath.log. If any failed restarts were identified, execute steps 2 through 4 on all nodes. -
Confirm a reboot is needed on each node.
Connect to the each node and run the following command:
ssh <username>@<ip-address> iptables-save 2>/dev/null | grep -i cali -cssh <username>@<ip-address> iptables-save 2>/dev/null | grep -i cali -cIf the result is not zero, a reboot is needed.
Reboot the node:
sudo rebootsudo reboot - Wait for the node to become responsive (you should be able to SSH to it) and repeat steps 2 through 4 on every other node.
