- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
This error could be found in the log of a failed job, with one of the following job names: services-preinstall-validations-job, kerberos-jobs-trigger, kerberos-tgt-update.
Solution
Make sure the AD user still exists, is active, and their password was not changed and did not expire. Reset the user's password and regenerate the keytab if needed.
Also make sure to provide the default Kerberos AD user parameter <KERB_DEFAULT_USERNAME> in the following format: HTTP/<Service Fabric FQDN>.
