- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Adding a new node to the cluster
You can add server and agent nodes to the deployment after installation to increase resourcing.
Adding nodes is supported in both the single-node evaluation profile and the multi-node HA-ready production profile. However, adding nodes in a single-node environment will not result in a multi-node HA-ready production environment as we do not support the transition between the two deployment profiles.
For instructions on how to download the packages required for adding a new node, see Downloading installation packages.
To add a new node to the cluster, take the following steps:
Create or provision a new node, and configure the disks and open ports according to the following: Configuring the machines.
Configure the node in the load balancer as follows: Configuring the load balancer.
Copy the installer package available at
/opt/UiPathAutomationSuitein any of the server nodes. -
For an online installation, run one of the commands below.
To navigate to the installer folder, run the following commands. Replace {VERSION} with the actual installer version. Example: replace {VERSION} with 2021.10.3 if you are using version 2021.10.3 of Automation Suite.
sudo su - chmod -R 755 /opt/UiPathAutomationSuite cd /opt/UiPathAutomationSuite/online_installer_{VERSION}sudo su - chmod -R 755 /opt/UiPathAutomationSuite cd /opt/UiPathAutomationSuite/online_installer_{VERSION} -
To add a new server node, run the following commands:
./install-uipath.sh -i ./cluster_config.json -o ./output.json -k -j server --accept-license-agreement./install-uipath.sh -i ./cluster_config.json -o ./output.json -k -j server --accept-license-agreement -
To add a new agent node, run the following commands:
./install-uipath.sh -i ./cluster_config.json -o ./output.json -k -j agent --accept-license-agreement./install-uipath.sh -i ./cluster_config.json -o ./output.json -k -j agent --accept-license-agreement
For an offline installation, follow these instructions: Step 4.2: Creating and joining all machines to the cluster.
Important:To add a new GPU, Task Mining, or Automation Suite Robots node node, follow these instructions:
