- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Using the Orchestrator Configurator Tool
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
The Orchestrator Configurator Tool is a bash script that allows you to place files and settings inside the Orchestrator deployment in Automation Suite. The tool helps you add storage files, credential store plugins, NLog extensions, new NLog configurations, and override appSettings.
The environment where you use the Orchestrator Configurator Tool must be able to run a bash script and have the following tools:
kubectl configured with a connection to the cluster
jq 1.6
rclone
Note:Follow these steps to install rclone.
Do not download and use the ArgoCD CLI tool independently. To maintain compatibility and ensure smooth operation, we recommend using the ArgoCD we bundle within the Automation Suite artifacts. To do that, you must add ArgoCD to your path from the latest installer by running the following command:
export PATH="$PATH:/opt/UiPathAutomationSuite/<version>/installer/bin"
To be able to run Orchestrator Configurator Tool from any location, follow these steps:
Update the
PATHvariable so as to include<installer-dir>/Tools. For example:export PATH="$PATH:/opt/UiPathAutomationSuite/online_installer_<version>/Tools" -
Make sure that the
jq --versionutility version is 1.6. If it's not, update it through one of these options:-
Option 1:
yum install -y epel-release yum install -y jqyum install -y epel-release yum install -y jq -
Option 2:
curl https://download-ib01.fedoraproject.org/pub/epel/7/x86_64/Packages/j/jq-1.6-2.el7.x86_64.rpm --output /tmp/jq-1.6-2.el7.x86_64.rpm yum localinstall /tmp/jq-1.6-2.el7.x86_64.rpm jq --versioncurl https://download-ib01.fedoraproject.org/pub/epel/7/x86_64/Packages/j/jq-1.6-2.el7.x86_64.rpm --output /tmp/jq-1.6-2.el7.x86_64.rpm yum localinstall /tmp/jq-1.6-2.el7.x86_64.rpm jq --version
Example:
Usage: ./orchestrator_configurator.sh \
-s blobstoragefolder -p pluginsfolder -n nlogextensionsfolder \
-c appsettings.json -l nlog.custom.config
-c|--app-settings
application configuration file containing json with key-value structure
-l|--nlog-config-file
nlog config file, json
-s|--storage-folder
location of the storage folder on the local disk
-n|--nlog-extensions-folder
location of the nlog extensions on the local disk
-p|--securestore-plugins-folder
location of the securestore plugins on the local disk
-d|--dry-run
do not update the orchestrator app with the new values
-y|--accept-all
do not prompt for confirmation of actions and overwriting of files with kubectl cp.
-c|--app-settings
-s|--storage-folder
-d|--dry-run
-y|--accept-all
To apply new application settings, run the following command:
./orchestrator_configurator.sh -c appsettings.json
If the appsettings.json file does not already exist, you can create it yourself, as shown in the following example:
"ExampleSetting.Enabled": true,
"ExampleSetting.Type": "BasicExample",
"ExampleSetting.Count": 3
To change NLog configuration, run the following command:
./orchestrator_configurator.sh -l nlog.custom.json
Example nlog.custom.config
"Nlog": {
"targets": {
"robotElasticBuffer": {
"flushTimeout": 1000,
"bufferSize": 1000,
"slidingTimeout": false,
"target": {
"uri": "https://elastic.example.com:9200",
"requireAuth": true,
"username": "elastic-user",
"password": "elastic-password",
"index": "${event-properties:item=indexName}-${date:format=yyyy.MM}",
"documentType": "logEvent",
"includeAllProperties": true,
"layout": "${message}",
"excludedProperties": "agentSessionId,tenantId,indexName"
"Nlog": {
"targets": {
"bufferSize": 1000,
"target": {
