Last updated Nov 6, 2025
Other troubleshooting
Failure to publish packages from Studio
In certain situations, some API calls to Automation Suite can result in a 413 response (or RequestEntityTooLarge error message). The conditions can occur when:
  1. The request is over 1MB in size.
  2. The HTTP version used is 1.1.
The issues is encoutered in common scenarios like publishing a package from Studio, uploading queueItems, or any other scenario where Activities or Studio are posting files or data to Orchestrator.
Solution
To avoid this issue, you can increase the default buffer limit to a larger value, such as 10MB. To do this, you can change the Envoy Filter settings to adjust per_connection_buffer_limit_bytes to a larger byte value.
The following example shows how to set per_connection_buffer_limit_bytes to 10000000 bytes:
cat > /tmp/increase_buffer_per_connection.yaml <<'EOF'
apiVersion: networking.istio.io/v1alpha3
kind: EnvoyFilter
metadata:
  namespace: istio-system
spec:
  configPatches:
  - applyTo: LISTENER
    patch:
      operation: MERGE
      value:
        per_connection_buffer_limit_bytes: 10000000 #10MB
EOF
kubectl apply -f /tmp/increase_buffer_per_connection.yamlcat > /tmp/increase_buffer_per_connection.yaml <<'EOF'
kind: EnvoyFilter
metadata:
spec:
  configPatches:
  - applyTo: LISTENER
    patch:
      operation: MERGE
      value:
EOF
  • Failure to publish packages from Studio
  • Description
  • Solution
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
