- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
uipathctl.sh script provides an automated way to upgrade a cluster to a newer version, configure a backup, restore a cluster, and more,
by running it on one node. The automation of these tasks is done via the IT automation tool Ansible.
Parameter |
Description |
Upgrade the cluster. |
Generate a sample file representing a Dex Connector for enabling SSO. |
Generate an example ArgoCD RBAC file. |
Generate the Kustomize overlays for the ArgoCD and Dex deployment with SSO. Useful in debugging. |
Generate and apply the Kustomize overlays for ArgoCD and Dex with SSO. |
This flag is shown only if you use the
upgrade command.
Steps to run during upgrade operations. Defaults to
all.
Type of installation. Required for upgrade and restore. |
Path to your
cluster_config.json file. If not specified, a configuration file is generated.
Path to a Kubeconfig file that allows connecting to the cluster. Defaults to
/etc/rancher/rke2/rke2.yaml.
Path to a valid Ansible inventory describing the cluster. If not specified, an inventory is generated. |
The username to be used by Ansible to connect to cluster nodes. Defaults to the current user. |
The SSH private key that provides connectivity to cluster nodes. If not specified, a set of passwords are prompted. |
Ask Ansible to request a password set for SSH connections and elevation. |
Specify the path to a custom
ansible.cfg to be used.
Path to the
sf-infra.tar.gz file. Required for offline upgrades.
Do not perform CNI upgrade. |
Connector type for
sso-generate-connector.
Path to a file containing a Dex Connector for the SSO integration. |
Ansible uses the SSH mechanism to log into any of the host nodes or machines to perform tasks.
uipathctl.sh script, you must take the following steps:
- Identify the Ansible host node.
- Add the SSH signature of your nodes to the known hosts.
- Set up the SSH authentication method.
- Install Ansible and other prerequisite tools.
You must ensure that the following tools are installed on the Ansible host node:
ansible(v2.8+)ansible-playbooksshpass– Required only when using password for authentication along with the --ansible-ask-password parameter.zip
For instructions, see the following sections.
The Ansible host node is the machine where you install Ansible. This machine must be a server node so that it has the required permissions to perform all the automations in the cluster.
In online installations, the Ansible host node can be any of the server nodes.
/uipath location. If there is no server node with the UiPath bundle disk attached, you can simply mount an additional disk to any
of the existing server nodes and consider it to be the Ansible host node.
known_hosts file in the Ansible host node.
<node-private-ip> with the private IP address of each node in the cluster, one at a time.
ssh-keyscan -H <node-private-ip> >> ~/.ssh/known_hostsssh-keyscan -H <node-private-ip> >> ~/.ssh/known_hostsAnsible supports two SSH mechanisms:
- Option 1: Key-based SSH authentication – Recommended. It uses private and public keys.
- Option 2: Password-based SSH authentication
Option 1: Key-based SSH authentication (recommended)
Step 1: Setting up the SSH key
The SSH key authentication mechanism uses a combination of private and public keys.
Make sure you grant access to the public key of the Ansible host node on all other nodes by copying it.
ssh-keygen command.
Generating SSH keys
ssh-keygen command. To generate the new SSH key, just run ssh-keygen command and follow the instructions.
To generate a new SSH key, take the following steps:
- Generate a new SSH key using the
ssh-keygencommand. -
Write down the location of your key. Default values are:
- Public Key:
~/.ssh/id_rsa.pub - Private Key:
~/.ssh/id_rsa
- Public Key:
- Grant access to the public key of the Ansible host node on all other nodes by copying it.
Granting access to the public key on each node
ssh-copy-id command. If the path of the SSH public key is not ~/.ssh/id_rsa.pub, make sure to replace it accordingly.
ssh-copy-id -i ~/.ssh/id_rsa.pub username@node-private-ipssh-copy-id -i ~/.ssh/id_rsa.pub username@node-private-ipStep 2: Providing SSH key access to Ansible
Ansible uses the SSH mechanism to log into host machines and perform the required installation. For this reason, you must provide the SSH key access to Ansible.
Choose between the following methods:
ssh-agent (recommended)
ssh-agent to obtain access to nodes. For more information about ssh-agent, see ssh-agent manual.
ssh-agent, run the following command:
eval "$(ssh-agent -s)"
ssh-add ~/.ssh/id_rsaeval "$(ssh-agent -s)"
ssh-add ~/.ssh/id_rsaOption 2: Using non-protected private key
--ansible-private-key parameter to your the uipathctl.sh script. The parameter takes the absolute path of private key and uses it for authentication.
--ansible-ask-password parameter to uipathctl.sh script. This parameter will prompt you to provide the password for authentication.
You must ensure that Ansible and the following other supporting tools are installed on the previously selected Ansible host node.
ansible(v2.8+)To check ifansiblewas installed, run:ansible --version &>/dev/null || echo "Error: Ansible is not installed"ansible --version &>/dev/null || echo "Error: Ansible is not installed" -
ansible-playbookTo check ifansible-playbookwas installed, run:ansible-playbook --version &>/dev/null || echo "Error: Ansible Playbook is not installed"ansible-playbook --version &>/dev/null || echo "Error: Ansible Playbook is not installed" -
sshpass– Required only when using password for authentication along with the--ansible-ask-passwordparameter.To check ifsshpasswas installed, run:sshpass -V &>/dev/null || echo "Error: sshpass is not installed"sshpass -V &>/dev/null || echo "Error: sshpass is not installed" -
zipTo check ifzipwas installed, run:zip --version &>/dev/null || echo "Error: zip is not installed"zip --version &>/dev/null || echo "Error: zip is not installed"Important: If any of the previous commands errors out, the targeted package is not installed on your machine. Make sure to install the required tools.
Enabling the yaml output
yaml output for Ansible by running the following command:
export ANSIBLE_STDOUT_CALLBACK=yamlexport ANSIBLE_STDOUT_CALLBACK=yamlThis feature was introduced in Ansible 2.9, and for certain installations, it has to be enabled by running the following command:
ansible-galaxy collection install community.generalansible-galaxy collection install community.generalERROR! Invalid callback for stdout specified: yaml message after installing the community.general collection, you can disable the yaml output by running the following command:
unset ANSIBLE_STDOUT_CALLBACKunset ANSIBLE_STDOUT_CALLBACKGenerating the Ansible inventory.ini file
inventory.ini file for Ansible. However, there are few situations where you must build and provide the inventory.ini file to Ansible. For example:
- While restoring the cluster from the backup data. This is because at the time of restore there is no healthy cluster to derive
inventory.ini. - When you want to provide advanced configuration such as username and SSH key, which is very specific to each node.
For more details, see How to build your own inventory.
uipathctl.sh script understands.
[FIRST_SERVER]
'10.0.1.1'
[SECONDARY_SERVERS]
'10.0.1.2'
'10.0.1.3'
[AGENTS]
'10.0.1.4'
'10.0.1.5'
[TASKMINING]
'10.0.1.6'
[GPU]
'10.0.1.7'
[ASROBOTS]
'10.0.1.8'
[all:vars]
ansible_connection=ssh
ansible_timeout=10
ansible_user=admin[FIRST_SERVER]
'10.0.1.1'
[SECONDARY_SERVERS]
'10.0.1.2'
'10.0.1.3'
[AGENTS]
'10.0.1.4'
'10.0.1.5'
[TASKMINING]
'10.0.1.6'
[GPU]
'10.0.1.7'
[ASROBOTS]
'10.0.1.8'
[all:vars]
ansible_timeout=10
ansible_user=admin|
Group |
Value |
The starting point where you run the
uipathctl.sh script. This is also called the Ansible host node.
You must provide the Private IP address for this node. |
The group of other server nodes in the cluster. You must provide the Private IP address of all the other server nodes. |
The group of agent nodes in the cluster. You must provide the Private IP address of all agent nodes. |
The group of Task Mining nodes in the cluster. You must provide the Private IP address of all the Task Mining nodes. |
The group of GPU nodes in the cluster. You must provide the Private IP address of all the GPU nodes. |
The group of Automation Suite Robots nodes in the cluster. You must provide the Private IP address of all the Automation Suite Robots nodes. |
The group of variables applied to all the previously defined host groups.
You can provide the variables per group or per host node. For details, see Assigning a variable to many machines: group variables. |
Generating the Ansible Variable File
Yaml file and provided to Ansible.
uipathctl.sh using --ansible-variables-file.
#Path where installer zip is available. By default, uipathctl.sh takes the current folder and compress it to zip before copying it to other nodes.
installer_path: /path/to/installer.zip
# Path where installer will be copied on nodes
target_installer_base_path: /opt/UiPathAutomationSuite/<version>/installer
# Install type - online or offline
install_type: online
# Path on nodes where offline bundles will be copied
target_bundle_base_path: /opt/UiPathAutomationSuite/{version}
# Path on nodes where offline bundles will be extracted
target_tmp_path: /opt/UiPathAutomationSuite/tmp
# Basepath and filname for the various config files and bundles on the local machine
cluster_config_filename: cluster_config.json
cluster_config_basepath: /var/tmp/uipathctl_{version}
backup_config_filename: backup_config.json
backup_config_basepath: /var/tmp/uipathctl_{version}
restore_config_filename: restore.json
restore_config_basepath: /var/tmp/uipathctl_{version}
infra_bundle_filename: sf-infra.tar.gz
infra_bundle_basepath: /var/tmp/uipath_upgrade_<version>#Path where installer zip is available. By default, uipathctl.sh takes the current folder and compress it to zip before copying it to other nodes.
infra_bundle_basepath: /var/tmp/uipath_upgrade_<version>|
Variable |
Value |
The path of
sf-installer.zip. If you do not provide this value, uipathctl.sh will zip the current directory and copy it to other nodes, as an installer zip.
The path where the installer will be copied on the nodes. The default value is `/opt/UiPathAutomationSuite/{version |
The installation method. Possible values are:
online and offline.
The path on the nodes where the offline bundles will be copied. The default location is
/var/tmp/uipathctl_{version}.
The path on the nodes where the bundle is extracted. The default location is
/opt/UiPathAutomationSuite/tmp.
The name of the cluster configuration file. The default value is
cluster_config.json.
The location where
cluster_config.json will be stored temporarily on the nodes during orchestration. The default value is /var/tmp/uipathctl_{version}.
The name of the backup configuration file. The default value is
backup.json.
The location where
backup.json will be stored temporarily on the nodes during orchestration. The default value is /var/tmp/uipathctl_{version}.
The name of the restore configuration file. The default value is
restore.json.
The location where
restore.json will be stored temporarily on the nodes during orchestration. The default value is `/var/tmp/uipathctl_{version
The name of the bundle containing the infrastructure layers. This is the same as the one you provided to the
The location where
sf-infra.tar.gz will be stored temporarily on the nodes during orchestration. This is the same as the one you provided to the uipathctl.sh script.
- Uipathctl.sh Parameters
- Requirements
- Identifying the Ansible host node
- Adding the SSH signature of your nodes to the known hosts
- Setting up SSH authentication method
- Option 1: Key-based SSH authentication (recommended)
- Checking if Ansible and other prerequisite tools are installed
- Advanced Ansible configuration
- Enabling the yaml output
- Generating the Ansible inventory.ini file
- Generating the Ansible Variable File
