- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Audit Logs Queries
- MongoDB Monitoring Dashboard
- MongoDB Certificate Renewal
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
MongoDB uses two types of certificates for a secure connection within the Automation Suite cluster:
- CA root certificate
- TLS certificate
Starting with 2022.4.0, the MongoDB certificates generated during installation are valid for three years.
For environments upgraded from versions before 2021.10.3 to 2022.4, follow the steps described in this page for MongoDB certificate rotation. The generated MongoDB certificates are valid for three years.
For fresh 2022.4 installations and onward, the certificate rotation is done automatically. The CA certificate is renewed automatically 30 days before it expires, while the TLS certificate is renewed 20 days before it expires. Because of this, there is no user intervention needed to maintain the validity of the certificates.
However, if you want to renew the certificates manually, you can use the certificate rotation CLI. Follow the steps below to run the certificate rotation.
SSH to the VM node.
ssh <username>@<node-fqdn>ssh <username>@<node-fqdn> -
Assume the super user role by running the command below.
sudo susudo su -
Go to the installation (for fresh installations) or upgrade (for upgraded environments) directory by running the command below.
cd <Installation/Upgrade Directory>cd <Installation/Upgrade Directory> -
Copy the
rotate-cert.shscript below to the installation directory../configureUiPathAS.sh mongodb rotate-certificate kubectl -n mongodb get secret/tls-ca-key-pair -o jsonpath='{.data.ca\.crt}' | base64 -d > /tmp/.certs/ca.crt kubectl -n mongodb create configmap mongo-ca --from-file="/tmp/.certs/ca.crt" --dry-run=client -o yaml | kubectl replace -f - kubectl rollout restart sts mongodb-replica-set -n mongodb./configureUiPathAS.sh mongodb rotate-certificate kubectl -n mongodb get secret/tls-ca-key-pair -o jsonpath='{.data.ca\.crt}' | base64 -d > /tmp/.certs/ca.crt kubectl -n mongodb create configmap mongo-ca --from-file="/tmp/.certs/ca.crt" --dry-run=client -o yaml | kubectl replace -f - kubectl rollout restart sts mongodb-replica-set -n mongodb -
Run the certificate rotation script by using the command below.
chmod u+x rotate-cert.sh ./rotate-cert.shchmod u+x rotate-cert.sh ./rotate-cert.sh
The certificate rotation script takes around 5-10 minutes to complete. The new certificates generated by the script are valid for three years from the time of creation and are automatically renewed as per the timeline mentioned above.
