- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- RKE2 not getting started due to space issue
- SQL validation fails during upgrade
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
During an RKE2 upgrade, the newly installed snapshot-controller conflicts with the pre-existing snapshot-controller. As a result, the installation pod for snapshot-controller-crds enters a CrashLoopBackOff state.
Solution
To fix this issue, take the following steps:
Update the
/etc/rancher/rke2/config.yamlfile with the following details on all server nodes:disable: - rke2-ingress-nginx - rke2-snapshot-controller - rke2-snapshot-controller-crd - rke2-snapshot-validation-webhookdisable: - rke2-ingress-nginx - rke2-snapshot-controller - rke2-snapshot-controller-crd - rke2-snapshot-validation-webhook -
Restart the
rke2-serverusing the following command:systemctl restart rke2-server.servicesystemctl restart rke2-server.service -
Run the following commands to clean up the existing snapshot controller pods:
to clean up the
snapshot-controller-crdinstallation job:kubectl delete jobs -n kube-system helm-delete-rke2-snapshot-controller-crd --ignore-not-foundkubectl delete jobs -n kube-system helm-delete-rke2-snapshot-controller-crd --ignore-not-found -
to clean up the
snapshot-controllerinstallation job:kubectl delete jobs -n kube-system helm-install-rke2-snapshot-controller --ignore-not-foundkubectl delete jobs -n kube-system helm-install-rke2-snapshot-controller --ignore-not-found -
to clean up the
snapshot-controllerdeployments:kubectl delete deploy -n kube-system snapshot-controller, rke2-snapshot-controller --ignore-not-foundkubectl delete deploy -n kube-system snapshot-controller, rke2-snapshot-controller --ignore-not-found
