- Overview
- Requirements
- Root privileges requirements
- High Availability – three availability zones
- Certificate Requirements
- Network requirements
- Validating the prerequisites in a single-node evaluation setup
- Validating the prerequisites in a multi-node HA-ready production setup
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Before installing Automation Suite, it is good practice to validate the installation prerequisites and infrastructure readiness. You can use the validateUiPathASReadiness.sh script to evaluate your environment and generate a summary before performing the installation.
| Validation | Description |
Hardware requirements |
Validates that each machine in the cluster meets the hardware requirements. The check takes into account the following aspects:
Disk partitioning and configuration |
Validates that you properly partitioned and configured the disk. The check takes into account the following aspects:
SQL Server connectivity |
Validates the connectivity to the configured SQL Server and database. The check takes into account the following aspects:
Server certificate |
Checks that the server certificate you provided is valid. The check takes into account the following aspects:
Token-signing certificate |
Checks that the token-signing certificate you provided is valid. The check takes into account the following aspects:
Proxy |
Validates that you properly configure the proxy. The check takes into account the following aspects:
Connectivity |
Validates that all machines can connect to each other, that all the required URLs are on the firewall allowlist, and more. The check takes into account the following aspects:
System services |
Validates that system services are properly configured. The check takes into account the following aspects:
Software requirements |
Validates that all the required software is installed. If some software is not installed, the |
Using the script to validate installation prerequisites
Downloading the Script
For offline installations, you must perform this step on a machine with access to internet and to the air-gapped machines where Automation Suite is deployed. Copy the file from the online machine to the first target machine.
The prerequisite script is packaged along with the installer in an archive called sf-installer.zip, and supporting tools are bundled as sf-infra.tar.gz for offline only. You need these files to generate a report on all the machines on which you plan to install Automation Suite.
| Installation type | Files to download |
| Online | sf-installer.zip – Mandatory. For download instructions, see sf-installer.zip. |
| Offline | sf-installer.zip – Mandatory. For download instructions, see sf-installer.zip.sf-infra.tar.gz – Mandatory. For download instructions, see sf-infra.tar.gz. |
Preparing to Use the Script
Become root by running the following command:
sudo su -sudo su - -
Copy the files to the
/opt/UiPathAutomationSuite/{version}folder by running the following command:VERSION="" #add the version number you are trying to install. Ex: for 2022.4.0 Set VERSION="2022.4.0" mkdir -p /opt/UiPathAutomationSuite/${VERSION} # For below command replace the /path/to where actually the files are present. cp /path/to/sf-installer.zip /opt/UiPathAutomationSuite/${VERSION} # Additionally for offline, copy sf-infra.tar.gz as well to /opt/UiPathAutomationSuite/{VERSION} folder cp /path/to/sf-infra.tar.gz /opt/UiPathAutomationSuite/${VERSION} cd /opt/UiPathAutomationSuite/${VERSION}VERSION="" #add the version number you are trying to install. Ex: for 2022.4.0 Set VERSION="2022.4.0" mkdir -p /opt/UiPathAutomationSuite/${VERSION} # For below command replace the /path/to where actually the files are present. cp /path/to/sf-installer.zip /opt/UiPathAutomationSuite/${VERSION} # Additionally for offline, copy sf-infra.tar.gz as well to /opt/UiPathAutomationSuite/{VERSION} folder cp /path/to/sf-infra.tar.gz /opt/UiPathAutomationSuite/${VERSION} cd /opt/UiPathAutomationSuite/${VERSION} -
Unzip the package by running the following command:
unzip sf-installer.zip -d installerunzip sf-installer.zip -d installer -
Assign the necessary permissions and navigate to the script folder by running the following command:
chmod -R 755 installer cd installerchmod -R 755 installer cd installer
Script Parameters
To view the help section and supported flags, run the following command:
./validateUiPathASReadiness.sh --help
Output:
validateUiPathASReadiness.sh Runs pre-install validation checks
Usage:
validateUiPathASReadiness.sh [command]
validateUiPathASReadiness.sh [flags]
Available Commands:
validate-packages Validate that required packages are installed
install-packages Install required packages. If --install-type offline, this will also install offline required packages
Arguments:
-i|--input Specify cluster config json file. Defaults to /opt/UiPathAutomationSuite/cluster_config.json
-d|--debug Debug mode to get additional details helpful for debugging
-m|--machines Comma separated IP address / hostnames of all the machines
-n|--node-type Possible values [server|agent|taskmining|asrobots|gpu]. Defaults to server
--install-type Possible values [online|offline]. Defaults to online
--prereq-bundle </uipath/offline_bundle.tar.gz> Specify the path to the prereq bundle
--prereq-tmp-folder </uipath> Specify parent directory for the temporary install folder
--kubeconfig Specify path to the kubeconfig file
-h|--help Display help
Usage:
Available Commands:
Arguments:
The following table describes the parameters you can use when running the script:
| Parameter | Description |
-i|--input | Accepts the cluster_config.json file as input. This file defines the parameters, settings, and preferences applied to the UiPath services deployed via Automation Suite. For details, see Advanced Installation Experience.If you do not provide this file, the script will trigger the interactive experience to collect these inputs. The file will then be generated on your behalf. |
-d|--debug | Debug mode to get additional details helpful for debugging. |
-m|--machines | Accepts comma-separated IP address / hostnames of all the machines. This is required to check the connectivity between all the nodes on the required port. The parameter is mandatory for multi-node HA-ready production installations. In addition to that, the parameter is also required if you plan to add a Task Mining, GPU, or Automation Suite Robots node in a single-node evaluation cluster. |
-n|--node-type | Accepts the type of the current node. Possible values are: server, agent, task-mining, gpu, and asrobots.The default value is server. |
--install-type | Accepts the installation method: online or offline.The default value is online. |
--prereq-bundle | Accepts the absolute path where the sf-infra.tar.gz is located. |
--prereq-tmp-folder | Accepts the absolute path where sf-infra.tar.gz bundle will be temporarily extracted. If this path is not provided, the installer will select the /tmp folder. |
--kubeconfig | Specify the path to the kubeconfig file. |
validate-packages | Validates the required RPM packages. |
install-packages | Installs the required RPM packages for online installation. |
install-packages --install-type offline | Installs the RPM required packages for offline installation. |
Validating a multi-node HA-ready production setup
On the First Server Machine
- To validate the first server machine, run the following command:
Online
./validateUiPathASReadiness.sh \
--node-type server \
--install-type online \
--machines "10.0.1.8, 10.0.1.9" #replace with actual machine IPs of all the nodes in cluster
Offline
--install-type offline \
--prereq-bundle ../sf-infra.tar.gz \
--prereq-tmp-folder /opt/UiPathAutomationSuite/tmp \
Once this script is executed, it generate sa cluster_config.json file under the /opt/UiPathAutomationSuite folder. This file is required on all the other machines.
- To copy the
cluster_config.jsonfile on the other machines, run the following command:
scp /opt/UiPathAutomationSuite/cluster_config.json <username>@<node dns>:/opt/UiPathAutomationSuite
If you cannot copy the file to the /opt/UiPathAutomationSuite folder due to permission errors, you can temporarily copy it to /var/tmp on the new machines, and then move it to /opt/UiPathAutomationSuite.
Alternatively, you can also provide full access permissions (777) to the /opt/UiPathAutomationSuite folder on the new machines, by running the following command: chmod -R 777 /opt/UiPathAutomationSuite.
On the Other Server Machines
To validate the other server machines, run the following command:
Online
--input /opt/UiPathAutomationSuite/cluster_config.json \
--machines "10.0.1.8, 10.0.1.9" #replace with actual machine IP of all the nodes in cluster
Offline
On Agent Machines
To validate the agent machines, run the following command:
Online
--node-type agent \
--machines "10.0.1.8, 10.0.1.9" # replace with actual machine IP of all the nodes in cluster
--node-type agent \
Offline
--node-type agent \
--install-type offline \ #replace with offline for airgap
--node-type agent \
On Specialized Agent Machines
To validate the Task Mining, GPU, or Automation Suite Robots machines, run the following command:
Make sure to use the suitable parameter to identify your specialized agent node:
- for Task Mining machines, use
--node-type task-mining - for GPU machines, use
--node-type gpu - For Automation Suite Robots machines, use
--node-type asrobots
Online
--node-type task-mining \ #replace with gpu for GPU node or asrobots for Automation Suite Robots node
Offline
