Patch artifact download links
Download links for patch artifacts required to apply patches to Automation Suite on Linux in Automation Suite.
This page provides the download links for the artifacts required to apply a patch.
2.2510.2 patches
This section provides the download links for the artifacts required for Automation Suite on Linux 2.2510.2 patches.
2.2510.2+patch2
uipathctl
To download uipathctl for Automation Suite 2.2510.2+patch2, run one of the following commands, depending on your OS:
  • Linux:
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2-patch2/uipathctl-2.2510.2-patch2-linux-amd64.tar.gz
  • Windows:
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2-patch2/uipathctl-2.2510.2-patch2-windows-amd64.tar.gz
  • MacOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2-patch2/uipathctl-2.2510.2-patch2-darwin-amd64.tar.gz
as-images.txt
To download as-images.txt for Automation Suite 2.2510.2+patch2, run the following command:
wget -O as-images.txt https://download.uipath.com/automation-suite/2.2510.2+patch2/embedded-images.txt
as-helm-charts.txt
To download as-helm-charts.txt for Automation Suite 2.2510.2+patch2, run the following command:
wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2.2510.2+patch2/embedded-helm-charts.txt
mirror-registry.sh
To download mirror-registry.sh for Automation Suite 2.2510.2+patch2, run the following command:
wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2.2510.2+patch2/mirror-registry.sh
hydrate-registry.sh
To download hydrate-registry.sh for Automation Suite 2.2510.2+patch2, run the following command:
wget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2.2510.2+patch2/hydrate-registry.sh
as.tar.gz
To download as.tar.gz for Automation Suite 2.2510.2+patch2, take one of the following steps:
  • To download the full as.tar.gz, run the following command:
    wget -O as.tar.gz https://download.uipath.com/automation-suite/2.2510.2+patch2/as-2.2510.2+patch2.tar.gz
  • To download the split as.tar.gz, run the following command:
    https://download.uipath.com/automation-suite/2.2510.2+patch2/as-2.2510.2+patch2-part-001
    https://download.uipath.com/automation-suite/2.2510.2+patch2/as-2.2510.2+patch2-part-002
    https://download.uipath.com/automation-suite/2.2510.2+patch2/as-2.2510.2+patch2-part-003
    https://download.uipath.com/automation-suite/2.2510.2+patch2/as-2.2510.2+patch2-part-004
as-fs.tar.gz
To download as-fs.tar.gz for Automation Suite 2.2510.2+patch2, run the following command:
wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2.2510.2+patch2/as-fs-2.2510.2+patch2.tar.gz
docker-images.json
To download docker-images.json for Automation Suite 2.2510.2+patch2, run the following command:
wget -O docker-images.json https://download.uipath.com/automation-suite/2.2510.2+patch2/docker-images.json
versions.json
To download versions.json for Automation Suite 2.2510.2+patch2, run the following command:
wget -O versions.json https://download.uipath.com/automation-suite/2.2510.2+patch2/versions.json
2.2510.2+patch1
uipathctl
To download uipathctl for Automation Suite 2.2510.2+patch1, run one of the following commands, depending on your OS:
  • Linux:
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2-patch1/uipathctl-2.2510.2-patch1-linux-amd64.tar.gz
  • Windows:
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2-patch1/uipathctl-2.2510.2-patch1-windows-amd64.tar.gz
  • MacOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2-patch1/uipathctl-2.2510.2-patch1-darwin-amd64.tar.gz
as-images.txt
To download as-images.txt for Automation Suite 2.2510.2+patch1, run the following command:
wget -O as-images.txt https://download.uipath.com/automation-suite/2.2510.2+patch1/embedded-images.txt
as-helm-charts.txt
To download as-helm-charts.txt for Automation Suite 2.2510.2+patch1, run the following command:
wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2.2510.2+patch1/embedded-helm-charts.txt
mirror-registry.sh
To download mirror-registry.sh for Automation Suite 2.2510.2+patch1, run the following command:
wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2.2510.2+patch1/mirror-registry.sh
hydrate-registry.sh
To download hydrate-registry.sh for Automation Suite 2.2510.2+patch1, run the following command:
wget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2.2510.2+patch1/hydrate-registry.sh
as.tar.gz
To download as.tar.gz for Automation Suite 2.2510.2+patch1, take one of the following steps:
    wget -O as.tar.gz https://download.uipath.com/automation-suite/2.2510.2+patch1/as-2.2510.2+patch1.tar.gz
    https://download.uipath.com/automation-suite/2.2510.2+patch1/as-2.2510.2+patch1-part-001
    https://download.uipath.com/automation-suite/2.2510.2+patch1/as-2.2510.2+patch1-part-002
    https://download.uipath.com/automation-suite/2.2510.2+patch1/as-2.2510.2+patch1-part-003
    https://download.uipath.com/automation-suite/2.2510.2+patch1/as-2.2510.2+patch1-part-004
    https://download.uipath.com/automation-suite/2.2510.2+patch1/as-2.2510.2+patch1-part-005
    https://download.uipath.com/automation-suite/2.2510.2+patch1/as-2.2510.2+patch1-part-006
    https://download.uipath.com/automation-suite/2.2510.2+patch1/as-2.2510.2+patch1-part-007
    https://download.uipath.com/automation-suite/2.2510.2+patch1/as-2.2510.2+patch1-part-008
    https://download.uipath.com/automation-suite/2.2510.2+patch1/as-2.2510.2+patch1-part-009
    https://download.uipath.com/automation-suite/2.2510.2+patch1/as-2.2510.2+patch1-part-010
    https://download.uipath.com/automation-suite/2.2510.2+patch1/as-2.2510.2+patch1-part-011
    https://download.uipath.com/automation-suite/2.2510.2+patch1/as-2.2510.2+patch1-part-012
    https://download.uipath.com/automation-suite/2.2510.2+patch1/as-2.2510.2+patch1-part-013
as-fs.tar.gz
To download as-fs.tar.gz for Automation Suite 2.2510.2+patch1, run the following command:
wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2.2510.2+patch1/as-fs-2.2510.2+patch1.tar.gz
docker-images.json
To download docker-images.json for Automation Suite 2.2510.2+patch1, run the following command:
wget -O docker-images.json https://download.uipath.com/automation-suite/2.2510.2+patch1/docker-images.json
versions.json
To download versions.json for Automation Suite 2.2510.2+patch1, run the following command:
wget -O versions.json https://download.uipath.com/automation-suite/2.2510.2+patch1/versions.json
2.2510.0 patches
This section provides the download links for the artifacts required for Automation Suite on Linux 2.2510.0 patches.
2.2510.0+patch2
uipathctl
To download uipathctl for Automation Suite 2.2510.0+patch2, run one of the following commands, depending on your OS:
  • Linux:
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0-patch2/uipathctl-2.2510.0-patch2-linux-amd64.tar.gz
  • Windows:
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0-patch2/uipathctl-2.2510.0-patch2-windows-amd64.tar.gz
  • MacOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0-patch2/uipathctl-2.2510.0-patch2-darwin-amd64.tar.gz
as-images.txt
To download as-images.txt for Automation Suite 2.2510.0+patch2, run the following command:
wget -O as-images.txt https://download.uipath.com/automation-suite/2.2510.0+patch2/embedded-images.txt
as-helm-charts.txt
To download as-helm-charts.txt for Automation Suite 2.2510.0+patch2, run the following command:
wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2.2510.0+patch2/embedded-helm-charts.txt
mirror-registry.sh
To download mirror-registry.sh for Automation Suite 2.2510.0+patch2, run the following command:
wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2.2510.0+patch2/mirror-registry.sh
hydrate-registry.sh
To download hydrate-registry.sh for Automation Suite 2.2510.0+patch2, run the following command:
wget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2.2510.0+patch2/hydrate-registry.sh
as.tar.gz
To download as.tar.gz for Automation Suite 2.2510.0+patch2, take one of the following steps:
    wget -O as.tar.gz https://download.uipath.com/automation-suite/2.2510.0+patch2/as-2.2510.0+patch2.tar.gz
    https://download.uipath.com/automation-suite/2.2510.0+patch2/as-2.2510.0+patch2-part-001
    https://download.uipath.com/automation-suite/2.2510.0+patch2/as-2.2510.0+patch2-part-002
    https://download.uipath.com/automation-suite/2.2510.0+patch2/as-2.2510.0+patch2-part-003
as-fs.tar.gz
To download as-fs.tar.gz for Automation Suite 2.2510.0+patch2, run the following command:
wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2.2510.0+patch2/as-fs-2.2510.0+patch2.tar.gz
docker-images.json
To download docker-images.json for Automation Suite 2.2510.0+patch2, run the following command:
wget -O docker-images.json https://download.uipath.com/automation-suite/2.2510.0+patch2/docker-images.json
versions.json
To download versions.json for Automation Suite 2.2510.0+patch2, run the following command:
wget -O versions.json https://download.uipath.com/automation-suite/2.2510.0+patch2/versions.json
  • 2.2510.2 patches
  • 2.2510.2+patch2
  • 2.2510.2+patch1
  • 2.2510.0 patches
  • 2.2510.0+patch2
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
