- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Copy the Orchestrator Certificate
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Last updated Jun 30, 2025
If AI CenterTM requires an external Orchestrator, you need to copy the Orchestrator and Identity Server certificate to the virtual machine before the installation or upgrade.
Note: In case of chain certificates, make sure to use the root certificate as show in Chain certificates section.
Download and save the Orchestrator certificate on your local machine. You can do this by using a browser, or you can ask your
IT department to provide the certificate. Certificates must be base64 and
.cer format. Copy the certificate to the virtual machine using the following command.
scp /path/to/orch.cer <username>@<node dns>:/opt/UiPathAutomationSuitescp /path/to/orch.cer <username>@<node dns>:/opt/UiPathAutomationSuiteIf Identity Server is different from Orchestrator, repeat the steps for
identityserver.cer as well.
Chain certificates
When using a domain-issued certificate, make sure to export the root certificate as follows:
The resulting file should be similar to the following example.
-----BEGIN CERTIFICATE-----
certificate
base64
encoded
-----END CERTIFICATE----------BEGIN CERTIFICATE-----
certificate
base64
encoded
