- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Azure Deployment Template
| Step | Instructions |
| Azure deployment architecture | Architecture diagram Components |
| Step 1: Preparing the Azure deployment | Azure subscription Quotas VM family region availability DNS |
| Step 2: Deploying Automation Suite to Azure | Deploying Automation Suite to Azure |
| Step 3: Post-deployment steps | Validating the installation Updating certificates Accessing deployment outputs Accessing cluster VMs DNS requirements Accessing the Cluster Administration portal Accessing Automation Suite general interface Accessing host administration Accessing ArgoCD Accessing Rancher Scaling your cluster Completing an upgrade Azure VM lifecycle operations |
