- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Migration steps
To start the migration operation, take the following steps:
- Move the Identity organization data from standalone to Automation Suite. Details...
- Restore the standalone product database. Details...
- Back up the platform database in Automation Suite. Details...
- Merge the organizations in Automation Suite. Details...
- Update the migrated product connection strings.
- Migrate standalone Insights. Details...
- Delete the default tenant. Details...
