- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
This page explains how you can perform an online Automation Suite installation with a multi-node HA-ready production setup.
You must meet the hardware and software prerequisites before proceeding with the installation. See Hardware and software requirements.
You can use a dedicated script to validate the installation prerequisites and infrastructure readiness. See Validating the prerequisites.
For a smooth installation experience, make sure to follow our best practices. See .
These steps help you install the Automation Suite across multiple machines. Internet access is required for this installation mode.
The installation process has the following general steps:
Step |
Description |
Step 1: Download the installation packages |
You need to perform this step from a machine with access to the internet where you plan to deploy Automation Suite. While the installation packages finish downloading, you can continue to some of the next steps. |
Step 2: Configure the installation | Step 2.1: Run the interactive installer to configure the installation options The tool gathers inputs for most common options and generates a configuration file. The default installation configuration includes a shared SQL server to be used by all products. To customize the installed products or have separate SQL servers used for specific products, edit the configuration file. |
Step 3: Complete the installation | Step 3: You have completed the installation successfully and can move to post-installation steps. You can now access the newly created cluster and suite, update certificates, resize the PVC, and more. |
RHEL kernel version kernel-4.18.0-477.10.1.el8_8 is affected by an issue that interrupts the installation or management of the Automation Suite cluster. Make sure that none of the Automation Suite nodes uses this kernel version either pre- or post-installation. You can update the kernel version by running the following command:
dnf install -y kernel kernel-tools kernel-tools-libsdnf install -y kernel kernel-tools kernel-tools-libsYou must perform this step from a machine with internet access where Automation Suite will be deployed. While these are finishing downloading, you can continue with the next steps.
To copy the interactive installer to the target machine, take the following steps:
Run the installer on the first server only.
chmod +x ~/installUiPathAS.sh
./installUiPathAS.shchmod +x ~/installUiPathAS.sh
./installUiPathAS.shStep 2.1: Default configuration
Run the interactive installer to configure the installation options. The tool gathers inputs for the most common installation options and generates a configuration file. High Availability is enabled by default, but you can disable it using the advanced configuration.
To install Automation Suite, take the following steps:
Step 2.2: (Optional) Advanced configuration
This step is optional.
You can configure the file for more advanced configurations. You can enable additional products, disable any of the default products, configure your SQL DBs and their respective connection strings, and certificates. For multi-node HA-ready production mode, we enable High Availability by default, but you can disable it if needed.
For advanced configuration, you can follow the following instructions: Advanced installation experience.
Updating Certificates
The installation process generates self-signed certificates on your behalf. However, the Azure deployment template also gives you the option to provide a CA-issued server certificate at installation time instead of using an auto-generated self-signed certificate.
Self-signed certificates will expire in 90 days, and you must replace them with certificates signed by a trusted CA as soon as installation completes. If you do not update the certificates, the installation will stop working after 90 days.
For instructions, see Managing certificates.
Accessing Automation Suite
To access the newly created cluster and suite, see Accessing Automation Suite.
Completing an AI Center installation
If AI Center requires an external Orchestrator, run the following command to complete the installation:
./configureUiPathAS.sh aicenter configure --installation-token <identity token>./configureUiPathAS.sh aicenter configure --installation-token <identity token>Resizing PVC
To resize the PVC, see Resizing PVC.
- Overview
- Step 1: Downloading the installation script and running the interactive installer
- Step 2: Configuring the installation
- Step 2.1: Default configuration
- Step 2.2: (Optional) Advanced configuration
- Step 3: Completing the Installation
- Updating Certificates
- Accessing Automation Suite
- Completing an AI Center installation
- Resizing PVC
